Wheel Studs--Help
Old Apr 18, 2006 | 06:05 PM
Mikriman's Avatar
Default Wheel Studs--Help
How do you get the old wheel studs off to replace with new ones?
BFH?????
Old Apr 18, 2006 | 10:29 PM
OctaneZ28's Avatar
Pretty much. Takes several whacks, but they come out.
Some people take the hubs off in order to be safer, but I don't and I've never had any problems.
Old Apr 19, 2006 | 03:21 PM
Trev_SS's Avatar
what do you need to put new ones on for just wonderign
Old Apr 19, 2006 | 03:26 PM
OctaneZ28's Avatar
I just put the stud in place by hand, then I toss a few washers on it and tighten a lugnut on the stud to pull it into place.
This method works good.
Old Apr 19, 2006 | 06:43 PM
andypdbz's Avatar
i messed up the thread on one of them and im lazy...
anyone know a place that would do it for cheap?
Old Apr 19, 2006 | 06:51 PM
blown32's Avatar
Try any local shop or even a NAPA. Or one of your friends who has a shop press. Or Sears sells a kit to pull them into place.
Old Apr 19, 2006 | 06:55 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
any muffler/tire shop........
Old Apr 20, 2006 | 10:44 PM
Tim_WS6's Avatar
yup this actually works well. i had to replace one last night and i used that method
Old Apr 23, 2006 | 10:15 AM
BTTM's Avatar
Is the process on the rear the same as the front? I tried to bang the stud out with a hammer but noticed there's a gear behind the hub.
Old Apr 23, 2006 | 07:54 PM
BOOSTEDTA's Avatar
4 channel ABS.... the stock studs will hammer out and you can maneuver it out. If you're putting in new aftermarket (ARP, etc) longer ones, technically you have to pull the axles. BUT some people grind the head of the new ARP stud into a "D" shape and it gives it just enough clearance to slide in. That's what I did on my 99 WS6...
