Polishing wheels HELP
These tiny scratches are nothing major they look similair to spiderwebbing on cars, I'm just a perfectionist when it comes comes to things like this. I don't want to spend all this time doing this and not get the results I want.
You didn't sand high enough. Black emery compound on a cotton buffing wheel needs the surface finish to be at least 600 grit in order for it to be totally effective. Keep going: 320, 400, 500, 600, then hit it with a buff again. The red compound you mentioned CAN be used but it won't achieve any higher of a shine than the white compound as the red compound has no cutting action to it and therefore won't get the surface any smoother. However, the red compound is good for maintaining wheels that are already polished since it has a drier composition and won't leave behind as much residue as the white.
Just to get this straight. Sand to a 600 grit paper then hit it with the emery, then wash and hit it with the white.
1. Are the lips of your wheels clearcoated?
2. Had you previously stripped the clearcoat prior to attempting to sand?
3. If they were NOT clearcoated, were you just attempting to re-polish?
Your answers will determine the proper procedure.
