Tomzwheels
Old May 27, 2006 | 03:42 AM
sdiddy's Avatar
Default Tomzwheels
I'm looking at doing his Chrome Z06 18x9.5/10.5 combo but noticed the offset on the 10.5's are +58mm. That offset won't work with a 295 tire out back will it? I don't mind doing the bfh mod, but don't want to have to roll the fender lip.
Old May 27, 2006 | 09:23 AM
Mike02Z's Avatar
That offset will push the wheel further back into the wheel well and I'd bet you will need to use the BFH at least maybe even cut the bump stop. I doubt rolling the fenders will be required as the wheels will sit further back I believe. If they were a +38mm then a fender roll might be needed. Hard to be sure until you try them.
Old May 27, 2006 | 10:21 AM
dimasZ28's Avatar
get the +56mm offset if you can. I got the same combo from him with 56 and have no probs. No fender issue just bumpstop and BFH mods needed.
Old May 27, 2006 | 10:47 AM
SPANKY LS1's Avatar
I had 18x10.5 +58mm wheels on the rear of my 2002 Z28, with Kumho Escta MX 295/35/18 tires with no inner fenderwell mods needed. I did have an APHR though, and it was CLOSE, like 1/16" or so, but they never rubbed. No bumpstop issues, either, just had to jack up by the rearend to remove the wheels/tires, if I jacked the car, the rim would hit the bumpstop. Stock height fwiw.
Old May 27, 2006 | 01:14 PM
sdiddy's Avatar
Well my main concern is that when I lower it, it will have multiple clearance issues. I wanted to run the 295 but it seems as though I may have to go with the 285 and ask for a +56 mm offset. What do you guys think?
Dmiasz28: your car is not lowered is it?
Old May 27, 2006 | 01:25 PM
Mike02Z's Avatar
I would go with P275 9.5" on every wheel. Then you can rotate your tires. Have you ever seen a 285 next to a 275? There is barely any difference. 10mm is nothing and not even going to be visible when mounted IMHO.
Old May 27, 2006 | 02:55 PM
chargedws6's Avatar
I have a tomz 10.5 Z06 on the back of my car I'm running a toyo T1R 295/35/18 with no rubbing issues. the car is also lowered with a prokit.
Attached Thumbnails Tomzwheels-oc-spring-06-006.jpg   Tomzwheels-oc-spring-06-001.jpg
Old May 27, 2006 | 04:40 PM
treysoucie's Avatar
im also looking at running the 18x9.5, and 18x10.5 z06 rims... i had planed on 315's out back, but it looks like i wont?
lol, i didnt think it was a prob till reading this thread.... i had 245's up front, and 315's on a 10.5" wide 17" cobra r, on my lowered '96 mustang, w/ no problems at all...
Old May 27, 2006 | 07:32 PM
Mike02Z's Avatar
It may not be. All depends on the tire and the wheel offset. I've read where some guys run 315's on a 11" wheel and claim no rubbing. I've also read where guys with 295's and 10" wheels have rubbing issues. In general I think the TA has a bit more room out back than the Z but for some reason not all 315 tires are the same width. I would expect all 315's to be 315mm wide but from what I have read some are not as wide as others.
Old May 27, 2006 | 11:01 PM
MadIceV8's Avatar
Customizing Director
I have the same setup in the rear + I'm dropped 2". No problems at all, only thing I had to do was a little bit of BFH. 295/35/18 +58mm
Old May 27, 2006 | 11:16 PM
OUTLAWZ RACING's Avatar
Sorry to highjack but will wheels for a 99 vette fit on a f-body??????
Old May 28, 2006 | 04:05 AM
sdiddy's Avatar
So, you all think I can be confident in buying the 18x10.5 w/295 tire and not worry about havng a wheel/tire combo that won't work?
madicev8: any pics?
Old May 28, 2006 | 10:20 AM
SPANKY LS1's Avatar
Yes.
madicev8: any pics?
From his website:
Old May 28, 2006 | 12:47 PM
sdiddy's Avatar
Thanks guys!
