Cutting Fender Lip?
On the inside you can use a hammer. You don't have to massage much, depending upon what size tires you want to run.
Fill us in with some more info of your setup.
Bodyshops can roll or cut the fenderlips for you if you find out you need that done and dont want to wait to rent one or buy the tool yourself.
I rolled my lips flat against the wheel house without any cutting ect. The lip will stretch easily enough to roll flat against the wheel house.
http://www.ws6.com/wheels.htm
or just have them rolled, like I did and many others. it is by far the neatest and easiest.
Never use the BFH mod on the outer fender, unless you like going to the bodyshop to have your quarter panels fixed and painted. BFH is for the other side of the wheel well, where the gas tank is.
