Guys with Weld Prostars
Be prepared to spend time grinding the calipers to make them fit. You can run a 5/16" spacer on the front with longer studs and not have to touch the calipers, but on the rear you'll be grinding regardless.
15x3.5's............
Now you can do a 15X4 and thats the biggest ive seen fit.... but the grinding for those with a spacer is horrible....
Now i know Bogart makes a RR series wheel in a 17X6 and you can use a smaller 17" tire there and a 16X10 or there 15X10.
That set if my memory serves me correct is in the order of about $1700
I know at one time i was looking at the RR-10's in 17X6's up front for all the time.... 17X10's out back fro street and a 15X10 for the trackand it was $2200 and i believe that was before there price increase......
Here are mine.... My street setup......
Weld Prostar 15X3.5's up front and 15X8's out back 275/60 M/T Drag Radials.
Track
15X3.5 Weld Alumastars and Weld Prostar 15X10's with 28" Hoosiers
Kyle
