Is there anything you can do to get 555R's to wear evenly?
I have 275/40/17 555r's on my 9.5" wheels and I daily drive them at 17psi and the centers are practically bald, while the outside of the tread looks untouched. Is there anything you can do to stop this? I have some 17x11 ZR1's sitting in my room and the only thing stopping me from putting 555R's on them is the uneven wear. Would running them at 30psi help our would that just make it 2x worse? If there's nothing you can do I'm just going to get some 315 KD's...
35 psi is usually what is recommended for a street tire. It seems that a lot of people have this problem with nitto tires. Under-inflation usually causes the shoulders to wear faster and over-inflation causes the middle to wear faster. Have your alignment checked out and you might also have to replaced your shocks. People don't realize that bad shocks can cause uneven tire wear.
BMW ///M Nerd
Originally Posted by Jeremiah
Could the tire be to wide for the wheel?
17psi is way to low for the street. You can get away with it at the track, but stop at a gas station and fill them back up to 32psi on your way home.
And YES, tire PSI affects wear. Normally low air pressure will wear out the sides. High PSI wears the centers.
But with soft compound tires thats not the case.
Nah 275/40/17 is the correct size for him.
