bumpstops
That's the before and after. As mentioned, leaving them in mainly is just an inconvenience when you lift the car on a regular lift where the suspension is not supported and you want to take off the wheels. The wheel will hang up on the bumpstop and will be hard to remove, and impossible to re-mount without compressing the suspension.
Aside from that, you will most like have to use a big hammer to pound in the inner fender well....like shown here:
Just recoat with a can of rubberized undercoating which you can pick up at any autoparts place.
It would help greatly if you had an ajustable panhard bar to center the rear end. It worked wonders on my car, no more dicing and slicing of the tires from the fender lip.
Other than that...drive carefully and use your head....don't get it airborne, watch for steep inclines and driveways.
Manny
I am assuming you're talking about the fender lips, not the inner fender?
Lets put it this way, if you run just about any tire but a Nitto, you will have to pound in the inner fender well some as I have done. Best thing to do is just to throw them on there and drive around with them a bit, try some "challenging areas" that will give the suspesion a workout, like steep inclines. After that, take the wheels back off and look where the undercoating got rubbed off, that's where you'll have to hit it with the hammer.
As far as the fender lip goes, my car is a bad example. It's a 98, and they tend to sit an inch lower than 99+ cars. I bought it new, so I know it's never been lowered. Before installing the adjustable panhard bar, my passenger side rear tire got a few cuts from the fender lip, mainly due to some big dips in the road, or having people sitting in the back, but again, my car is about an inch lower stock from the factory than most 99+ cars. The panhard bar is your friend, get one and spend some time adjusting your rear end so it's perfectly centered, it can minimize any damage from that fender lip. Since I installed mine, I didn't slice up my rear passenger side tire anymore. I have a UMI double adjustable rod ended panhard bar, makes centering the rear end easy since you don't have to unbolt it every time you adjust it.
Good luck! It's a bit of work, but it sure is worth it!
Hey, no problem! I have had mine on for a long time. When I first asked about it, not too many people had them, and as a result I didn't get too much info about it. So since I now know what's what with 315's, I almost feel obligated to answer almost any question about them.
Manny
All you are doing is now allowing your rear axle to move upwards more, inrcrease the chance of wheel well contact, and most like going to damage your shocks . . .
I never did ANTHING with mine. The ONLY issue was you cannot install the wheels with the axle hanging.
What other options are there to prevent contact between tire and bumpstop? Does anybody see a limiting strap/cable as a viable alternative? I don't get any hangtime in my car or anything but rather seek a "piece of mind" approach in customizing. If I were to shave the bumpstops back a little, how much clearance would be necessary to allow normal body roll/compression to not put the tire into the bumpstop?
