screw in tire
Old Dec 4, 2006 | 03:42 PM
anotherreject04's Avatar
Default screw in tire
looks like i picked up a lag screw someplace
also looks like ive been riding on it a long time, the head is nearly gone
its not leaking any air
should i leave it alone?
get it plugged?
how good are those tire plugs in this kind of situation?
Old Dec 4, 2006 | 03:43 PM
QuickT/A's Avatar
I would say get it patched on the inside
Old Dec 4, 2006 | 03:46 PM
'Trust''s Avatar
+1 on the inside patch, most places do it for free, or its $15.
Old Dec 4, 2006 | 04:19 PM
NOBR8KSS's Avatar
I don't know where you get it done for free... but +1 on getting it patched on the inside.
Old Dec 4, 2006 | 05:48 PM
2fast4u2catch's Avatar
if its not leaking i would leave it alone till it starts
Old Dec 4, 2006 | 05:51 PM
pro2low's Avatar
i would go get a patch/plug its a patch with a plug on it, its what most tire shops use now it will start leaking sometime.....ive also seen were the screw was long enough to scratch the inside of the rim up pretty good! i used to work at just tires haha
Old Dec 4, 2006 | 09:44 PM
CaMaRo67RS355's Avatar
patch on the inside that way you can spin'm if its on the rear..
Old Dec 4, 2006 | 11:05 PM
Streetracer361's Avatar
Sam's club will do it for free if you are a member or you know someone that is a member take them with you. By the way if they screw it up the have to buy you a new rim "if they scrach it" or a new tire if they screw that up. Trust me I work at the tire department at Sams in C.C.TX. If you lived down here I would fix it for you. If its not leaking then it probubley didn't go throw. Hope that helps you out.
Old Dec 5, 2006 | 01:22 AM
wabmorgan's Avatar
+2 Patch
Old Dec 5, 2006 | 10:38 AM
01350ss's Avatar
Just because it's not leaking now doesn't mean the screw didn't go through. The screw I can garuntee did go through. Go get the damn thing fixed. Eventually it will get pushed into the tire and or fall out. That will lead to a rapid tire deflation. Not safe for you, the car, or the rim. Dont be cheap, go get a patch plug. Hell you can even do yourself. Autp parts store now sell the plugs. The plugs also work
Old Dec 5, 2006 | 10:41 AM
2000LS1TA's Avatar
Old Dec 5, 2006 | 06:35 PM
cocimitch's Avatar
Get it patched from inside rather than wait, and you Know it'll go out on you at the worst time...
Old Dec 5, 2006 | 06:46 PM
iroc85blu's Avatar
hey i work at discount tire and they do it for free patch and plug. As long as its not in the shoulder or the tread is to bald
Old Dec 9, 2006 | 07:27 AM
Jeff 97 Formula's Avatar
NTB does patch/plug combos. They fixed one of mine, and you almost can't tell!
Old Dec 9, 2006 | 07:43 AM
spy2520's Avatar
i'd patch it...
