Lowering issues with ZR1's?
Old Dec 7, 2006 | 02:30 PM
CaMaRo67RS355's Avatar
Question Lowering issues with ZR1's?
getting ready to buy chrome ZR-1s 17x9.5 in front and 17x11 in back will i have any issues with lowering my 02 SS?
Old Dec 7, 2006 | 03:22 PM
02NHRAtransAm's Avatar
the front no.... the rear more than likley will have fitment issues
Old Dec 7, 2006 | 03:26 PM
what kind of fitment issues?
Old Dec 7, 2006 | 03:47 PM
bumpstops will have to be removed/relocated... may have to do some sheetmetal work... im sure there are tons of topiocs on this already out there.
Old Dec 7, 2006 | 04:19 PM
'Trust''s Avatar
It depends on the tires you get, you'll probably have no modifications if you go with say a Sumitomo tire, or a Nitto 315. Its best to do the BFH mod and roll the fenders if you go with any ohter manufactures as they run wider.
No sheet metal work (like tubbing), at least not until you go to a 345mm tire.
Old Dec 7, 2006 | 04:45 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I only did the hammer mod and the aphr (with a 50mm offset/315s Goodyear GS D3s/lowered). Do not worry about bumpstops.
Old Dec 7, 2006 | 09:42 PM
whats the biggest tire width wise i can run with 17x11's? 315 or 345 or what? ill probably run the nitto 555r's
Old Dec 7, 2006 | 10:51 PM
i'll probably lower it like only a 1 & 1/2
Old Dec 7, 2006 | 10:57 PM
'Trust''s Avatar
You *could* run a 335, but I wouldn't do it. Stick with a 315 unless your getting a bigger wheel. I'm lowered almost 2 inches with 17x11's with WIDE 315's (They measure just over 12 inches across) and I have no problems, still have bumpstops too.
Old Dec 15, 2006 | 05:38 PM
anyone else had ZR-1's with a lowered car?
Old Dec 15, 2006 | 06:37 PM
mzoomora's Avatar
14 Second Truck Club
My fronts were fine, but I only had 275's on 9.5's in the back.
Old Dec 15, 2006 | 09:35 PM
casey02ws6's Avatar
I had to do the BFH mod 0- I did not need an adj phb or rolling my fenders.
Old Apr 27, 2007 | 04:31 PM
LS1speedy's Avatar
bump
need more info
Old Apr 27, 2007 | 04:51 PM
TheLS1Kid's Avatar
I have 17x11 ZR1's +50mm offset with 315/35-17 Goodyear Eagle F1 GS-D3's(the fattest 315 you can get).
All i had to do was BFH the inner fender. It wasnt even that bad. The metal bends fairly easy. Dont be scared of the BFH.
I did not need an adjustable panhard rod but i am going to get one because my rearend is not perfectly centered. I also dont need tubular LCA's but I am going to get a set just so i can have a little more clearance.
