spacers?
Old Dec 25, 2006 | 12:01 AM
tbird31's Avatar
Default spacers?
just wondering what the deal with spacers are...i'd like for my wheels to line up with the fender well and just was wondering how much, where to get them, if they're worth it, what size lol...basically information.
i have 17x9 Firehawks now...and was thinking about getting some...
any information would be greatly appreciated.
Old Dec 25, 2006 | 04:52 PM
tbird31's Avatar
anybody?
Old Dec 25, 2006 | 07:07 PM
tbird31's Avatar
come on...i know somebody is running spacers...
Old Dec 25, 2006 | 08:29 PM
bone324's Avatar
You can do a search with alot of info on this subject. I personally use 1" billet adapter spacers for the front wheels. I'm running 255's in front and it moves the wheels out even with the edge of the fender. I got them on ebay for about $65/pair. Generally, people here recommend against spacers altogether. But, most agree that as long as it's a 5/16" or smaller plate-style spacer, you can use stock wheel studs. I tried that and I just didn't have enough threads. Instead, I got Baer 1/2" billet spacers with longer ARP studs from Summit for the rear wheels. Still haven't installed them yet. Good luck.
Old Dec 25, 2006 | 11:39 PM
Xsta Z 28's Avatar
5/8" to 1/2" spacers will get you the look you want.
Old Dec 26, 2006 | 07:58 AM
tbird31's Avatar
finally! lol thank you very much for your knowledge bone324 and Xsta Z 28.
btw bone324, i saw the clip of your car in your sig...that thing sounds f-ing amazing!
Old Dec 26, 2006 | 08:12 AM
Ryanmgaspard's Avatar
I have 1/8th spacers on the rear with 315's. The spacers for me produce a vibration of an unbalanced tire between 60-80mph. Why not just put a couple of washers on each lug. It would be the same thing for about $1 a wheel. The rears are flush with the inner fender and at stock height won't rub. Pics aren't so good. If you want more for educational use let me know.
Old Dec 26, 2006 | 10:27 AM
Fulton 1's Avatar
Thumbs down
This is an absolutely ridiculous and dangerous suggestion. Under NO circumstances should you use washers instead of wheel spacers. For the safety of others who read this **** and don't know any better, please refrain from giving advice unless you know what you're talking about!
Old Dec 26, 2006 | 02:33 PM
There is no difference. I used washers on a car for over 3 years and had no problems. My wheel didn't come off, my lug didn't break. It's your advice over mine.
Old Dec 26, 2006 | 02:38 PM
black_z's Avatar
The only thing I have to add to this thread is that i would use longer wheel studs, and to make certain that the mating surfaces of the hub, wheel, and spacer are all very clean. Get out the wirebrush if they arent.
Old Dec 26, 2006 | 03:53 PM
SuIcIdAlPoNtIaC's Avatar
I have billiet aluminum 1" spacers for sale if interested?
Old Dec 26, 2006 | 04:20 PM
Fulton 1's Avatar
LOL. Ignorance is bliss, isn't it? I don't care what you ran on your car. You may have been lucky or likely just didn't subject your car to the same loads that someone else will. My advice is based on sound engineering principle and not hearsay or uncontrolled experimentation. The FACT is that simply using washers prevents full contact between the two mating surfaces, which can lead to flexing of the wheel itself under elevated cornering loads. This uneven load distribution can cause stud or even wheel failure. Of course, this doesn't even address the additional bending loads that you're applying to the wheel studs by pushing the wheel outboard without any additional support (like that provided by a proper hubcentric wheel spacer).
Old Dec 26, 2006 | 04:33 PM
michaelg589's Avatar
my 2 cents:
You should not go larger than 5/16 with the stock studs. I have the stock trans am wheels right now (16x8s) and I bought 5/16 spacers to help fit my new wheels that I just bought. I put the spacers on the stock wheels in the mean time (while im waiting for tires). The 5/16 spacers actually brought my wheels out a good amount. More than i thought they would. I think If you did that with your 17x9s it would look perfect.
