bfgoodrich kdw
Old Dec 25, 2006 | 11:45 PM
01Blk*SS*'s Avatar
Default bfgoodrich kdw
hey guys if i got bfgoodrich kdw 275/35/18 (front) and 295/35/18 Rear would the rear be the same tire size as the stock tires? reason im asking is b/c i dont want my speedo to go whack... thanks
Old Dec 25, 2006 | 11:50 PM
BLKWS.6's Avatar
Go to tire-rack and look at the specs for the tire and it will show all the sizes and rev. per mile on the tires. See if its the same. (compare only the rear).
Old Dec 26, 2006 | 02:09 AM
RollTideTA's Avatar
yes they will be
Old Dec 26, 2006 | 11:37 AM
MannyZ28's Avatar
The 295's are a tad taller....like around an inch. Not sure if it's enough to make a difference with your speedo. If anything your ABS might complain about it, but again, don't think the size difference would be enough. As mentioned check out their site or Tirerack for specs on the size of both tires, what you're looking for is overall tire diameter. The stock diameter is around 25.6"
Old Dec 26, 2006 | 12:34 PM
michaelg589's Avatar
the 295 is 26.1 inches tall and the 275 is 25.6 inches tall. the stock tire height is 25.6 so the rear will be a little taller. but it shouldnt be a problem at all
Old Dec 26, 2006 | 04:43 PM
SS LS1's Avatar
Guys I'm runnning 275/35/18 front and 295/35/18 rear w/o any problemw with the ABS system.
The rears will be slightly taller as mentioned above so your speedo will be slightly off. Nothing to worry about. But I did update my PCM after buying EFILive to the correct pulses per mile so my speedo is back on track. But you really don't need to do this as it doesn't affect it much.
Greg
Old Dec 26, 2006 | 04:45 PM
01Blk*SS*'s Avatar
SS LS1 how much did the mph change??? thanks guys
Old Dec 26, 2006 | 05:44 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I never recorded the difference, but when he says not much, he means it. I run the same sizes on my wheels, and I didn't really notice a difference, but corrected my speedo with HPT none-the-less.
Old Dec 27, 2006 | 08:01 AM
Xsta Z 28's Avatar
^ Same here.
Old Dec 27, 2006 | 02:50 PM
cjmatt's Avatar
81.954" is the circumference for the new tires , the old ones are 80.384" which is a 1.9% difference, so at 100 on the speedo, you will be actually going 101.9...not that big of a deal
Old Dec 27, 2006 | 04:45 PM
Y2K Pewter SS's Avatar
275/35/18 & 295/35/18 KDW 2s are what I am going to be running as well. The .5 difference shouldn't affect the ABS or have that much affect on the speedo, less than 5MPH.
