anyone runnin E/T Streets!!
I have ran those same tires with the same problems. They sway like **** on the road and are just flat out dangerous in the rain. If you plan to drive it on the street any I would go with the ET/Street radials. But if it is a track only car they will be fine. The sidewall really allows you to hit them very hard off the line but is very unsettling on the street. But that is just my opinion.
I like the ET street for the track only. I know what work works for me so I'm stickin to it. Mabey someday I'll sack up and try the MT drag radials.
I have a spare set of rims and the only time the tires see the street is when I am driving to or from the track.
I would start out at 16 psi and see what happens. If your at the track and you have a little too much wheel spin take them down to 14psi. Its really just trial and error until you find the right psi to work with your setup, track conditions, and weather conditions.
I noticed your from Mission so i guess you run at EIRT, best thing to do is go around the water box and back up into it to wet the tires and roll out. everytime i would run, guys on street tires drove through the waterbox and staged right after, leaving the first couple of feet wet. my car would hook then spin right after the staging beams. the tires hook plenty, and there's no need run them at really low psi, just heat em up nicely. Good Luck!
so to answer your question, YES, you just wont get the full traction advantages as cars with modified suspensions... If you lowered your car with stiffer shocks the tires will have less effect bc of less weight transfer.
