275s on 17X11s?
Keep in mind, that was a 285 tire on an 11" wheel, and you're talking about a 275 tire. So I imagine the 275 would look even worse. Not saying it can't be done, but it will look stupid, IMO.
https://ls1tech.com/forums/showthrea...=275%2F40%2F17
now maybe one of you guys will help me with my question?
https://ls1tech.com/forums/wheels-tires/655546-big-kit-brembo-s-zr-1-s.html
I agree.
You can clearly see in those pics what I was refering to. The rim is wider than the tread of the tire, and the sidewall tapers inward as it goes up to meet the tread. Looks gay, IMO.
rpm most people would use those as a drag set-up anyway, not for show, so i don't know how the gay factor even comes in to play here.
you've really only got 3 choices anyway
nitto
mickey t's
or bfg's
and there's plenty of right ups on that.
at least there is still talk of m/t in a 315 for next month or 1st of april.
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
But also as stated above, the 17's, especially the 11" wide are a bad choice for drag use. They are so heavy it isn't funny. Consider the rotational mass of that wheel.
