? about the 17x11s
In this first picture, the bumpstop and the metal tab that it is mounted to is still in place and the suspension is compressed since the car is sitting on the floor.
In this second picture, the bumpstop has been unbolted and the mounting tab has been trimmed back. The suspension is at full droop with the car on a conventional lift. You can see how the tire just barely clears the remains of the mounting tab to which the actual bumpstop was bolted (you can see that we left the two mounting holes intact). Without trimming it, the wheel hangs up on the mounting tab, thus making it difficult to remove the wheel from the car when the car is in the air, and making it impossible to mount the wheel back on without compressing the suspension to gain enough clearance to get the wheel back into it's place.
Hope this clarifies it a bit.
Manny
So yes, there is a risk involved in doing what I did, but I have these wheels for 6 years now and haven't had a problem. Just think when you drive, be careful on steep inclines, and don't get the car airborne.
An adjustable panhard bar is a great idea too to center the rear end properly.
-Mike
-Mike
I kept my bumpstops after talking to Sam Strano about my setup. I trust him, and he has never given me a reason not to. Also, if I ever decide to get a second set of rear tires for autocrossing, they'll likely be 17x9.5. If I've completely removed the bumpstops and their mounts, I'm screwed.
-Mike
Before the next person asks, to fix that you should rent a heat gun and a fender roller. Roll the fender lips in a bit and that will keep it from gouging the tires.
If your sidewalls are OK, pull the wheels and look for spots where the tire has been rubbing the inner fender wells. Hit those spots with a hammer until the tire stops rubbing.
-Mike
And yeah, my Yokos got sliced up pretty good before I got a panhard bar, but ever since I put that thing on, I can't remember hearing anything scrape.
The rubbing usually occurs around this area:
In a way, I wish someone would make this topic a sticky, god knows I have answered the same question multiple times. Although there still is a bit of a difference in opinion as far as the safety of removing the bumpstops is concerned.
As you can see in the picture further up, I did retain the screw holes, so if I wanted to, I could put the bumpstops back in.
-Mike
-Mike
I know Mike....but one could always hope....lol
