Weld/draglites racing wheels backspacing?
Old 06-28-2007, 02:35 PM
LS69TA's Avatar
Originally Posted by LT1
which lug nut is better open or closed end 12mm X 1.50 ? i wont be running spacer with longer stud's. im going to grind till it fits.
Closed are fine if you aren't running it at the track. If you do, usually you will fail inspection because they want the studs to stick out past the lugs. Which is why alot of guys run the open ones with longer studs.
Old 06-28-2007, 10:09 PM
LT1
LT1's Avatar
ya i'll be going to the track so i better get open end lugs.
Quick Reply: Weld/draglites racing wheels backspacing?
