Staggered rim guys help....
Old Apr 24, 2007 | 10:48 PM
99camarosupersport's Avatar
Originally Posted by 1BadTA13
i dont understand what the big deal with buying a tire with a smaller sidewall int he front is???....i have the staggered too and yeah the fronts do look a little off right now but when i buy new tires im gonna go w/ matching sidewall's front and back...wtf is the big deal w/ that.....so the front will sit maybe....maybe a 1/2 inch at the most lower???
It just looks like ***, maybe I'm just too picky but i don't care for it personally. I thought when i put some new tires on the back it was going to be ok as i would try to match the prof. and even it out, but that's not going to work out. You shall find that out in time as i did.
It's ok Michael, we all have to *****.
Old Apr 25, 2007 | 09:07 AM
Xsta Z 28's Avatar
Because the ABS will not like it and could fail in a panic stop since the computer cannot calulate the tire speeds correctly.
And I agree, staggered diameter combos on F-Cars do not look right.
Old Apr 25, 2007 | 11:56 AM
1BadTA13's Avatar
can you or can you not change the tire/rim size via a programmer and correct that?
Old Apr 25, 2007 | 06:52 PM
Nine Ball's Avatar
LS1Tech Co-Founder
You cannot change the front and rear tires via pcm seperately, but you could 'trick' the pcm by altering the gear ratio to accomodate larger diameter tires in the rear.
better idea: Don't use staggered wheels on an f-body.
Old Apr 26, 2007 | 12:49 AM
Got some prices on TTM's today from tomzwheels, Not too bad really! I'm tossing between these and Rebels, what do you guys think?
Old Apr 26, 2007 | 08:31 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I like TTMs much better than Rebels.
Go with chrome or anthracid if your car is pewter (looks like it)
Old Apr 26, 2007 | 09:48 AM
chaman's Avatar
Tt Ftw.....
Old Apr 26, 2007 | 10:09 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Anthracid? Don't you guys mean Anthracite?
So staggered refers not to how wide the wheel is but differences in the diameter of the wheel too?
17x11, 17x9 = not staggered?
18x10.5, 17x9.5 = staggered?
Old Apr 26, 2007 | 04:03 PM
Xsta Z 28's Avatar
It can mean both, altough I typically refere to staggered as different diameters.
Old Apr 26, 2007 | 04:10 PM
That's what i was going by. Yes nineball my car is a dark pewter, and if i do go with the TTM's it's definately going to be black or anthracite, i've got a black and pewter scheme going on now, and i don't want to toss a third color in there.
I like anthracite, but i'm worried i'll get them and wish it were black like i have now.
(That picture isn't really too up to date, i've got a new manta stripe now and an SLP Grill, 20% tint, berger panel, and it's a 99 so the black mirrors also.)
Old Apr 26, 2007 | 07:13 PM
JudgeGuns's Avatar
kewel
Old Apr 26, 2007 | 07:44 PM
  #32
Nine Ball's Avatar
LS1Tech Co-Founder
PSJ, for some reason, they call TTM's "Anthracid" instead of "Anthracite". Guess their marketing guy couldn't spell?
99Camaro, if you already have the black accents, then the black wheels are the obvious choice!
Old Apr 27, 2007 | 04:49 PM
  #33
thanks guys.
