best street drag tire/wheel setup
what would be a good tire/wheel combo if i wanted to get two back wheels with drag radials to throw on before i went to the track..
nothing to expensive....
are there any other wheels that will work?? cause i mean i can buy a set of like Z06's or Zr1's or something? cause i have chrome 18" Z06's up front.. would it matter what wheels i put on the back..i dont care about looks but i have to drive about 30-45 mins to get the the track
Depends if you care how it looks.
If you want the car to look good with some drag rims get some Welds skinnies front 3.5's and 15x10's for rear and put MT ET Streets on em. If you don't care how they look get some cheap stockers with ET STreets
well what would be my best bet if i had to drive on them down the highway for like 30-45 min....i could care less how it looks just how it runs....
but if i had to drive on them for 45 min would et street radials be better or what??
2 Cents
I'd just get some 16" stock wheels and run the 255/50 MT street radials. If you want them then get some 17" or larger and run some other drag radials but they will not work as well and will cost a hell of a lot more. Et street radials will be perfectly fine on the highway and driving around just not soo good in the rain.
you can also get the Bias ply ET streets in 26" x 10.5" or 11.5" width and they will fit on a stock 16" as well or can be had to fit on a 17" rim but it would be good not not run those on the highway for extended times.
well ill probably go with the 255/50 MT with stockers... but i feel like thats so skinny
i dont know much about real drag tires but i feel like thats gonna look wired cause my fronts are 265's and rears are 295's right now ...but if they hook ill do it
well you wanted a low cost setup 255/50's on stock 16s are the way to go. No grinding modding, spacers, or anything with those. If you are worried about how it looks and want to really make sure the car will hook get some drag rims, slicks and skinnies and take weight out of the car. you should be making some good power with those mods so chances are you will need to do some tuning to get it to hook.
also would it be ok to leave the 18" zo6's up front on or should i switch the fronts out to some stockers to?
Originally Posted by dailydriver
If you can get a whole set of stock 16s cheap enough, I would just throw the least expensive, hardest, 225/55 16s on the front as sort of a low weight, low rolling resistance "cheap skinny". As a bonus, it would look good as well since it would be wwaaayyy narrower than the MT DR backs.
what tires are you gonna use on the front?
Pontiacerator
