17x10.5 with 315 question
But thanks I figured I'd need the "MAN TOOL" and wasn't sure on rolling the lip.
I just installed the exact set up you described in your first post, if you can stand very minor rub on hard turns (radio covers it) than you'll be fine at stock. I have found no evidence of the lip cutting anywhere and after spending $550+ on two new 315 Eagles you can bet I watching.
No problems when the car is setting on the ground with the suspension loaded, but when they put my car up on the lift to do the rear gears, the rear wheels wouldn't turn?!?
It appears the corners of the BS brackets were digging into the edge of the rims on both sides when the suspension was allowed to hang suspended - making the wheels impossible to turn. Unfortunately, they tried to force the wheels to turn at first and ended up gouging the backside edge of my rear rims...
