Problems with new rims
Bump stops missing=Car's fender may bottom out on tires. Nothing to do with ABS. (Unless you nicked a brake line... I can't envision that one.)
Differant overall diameter WILL interfear with your ABS. The over all diameter can be off a little... but it has to be close. It is the overall tires diameter that counts, not the aspect ratio.
My suggestion, get some P285/40/18 for the front.... and I bet that problem goes away.
Those 40 aspect ratio probably set the car up somewhat from the gound, and probably threw off your speedometer as well. A better choice would have been P285/35/18.
. Now my only problem is the lights, which I'm gonna go check out tomorrow. But now...I LOVE MY RIMS lol. Just wish they were a little bit wider...but that will come in time. The Best V8 Stories One Small Block at Time
There are also LOT of people that are running p275 on all fours. I've got p285/35r18 on all fours.... never seen a turning problem yet.
As for the bump stop.... If you only removed them.... it might be that. You may need a spacer back there.... depends on the offfset and if you are rubbing... especially metal to metal. {OK... glad to hear this problem has been solved for you}
Also, with my p285, being that they are 35 aspect ratio.... I DID NOT have to do the BFH.
The main thing is.... the tire MUST have approximately the same sidewall height.
p285/40 has a side wall height of 114mm
p255/35 had a side wall height of 89.25mm
That is a differance of 24.75mm. When you consider it is the over all tire diameter that counts.... that is really 24.75*2= 49.5mm. That's nearly 5cm of over all diameter differance.... which converts to an over all diameter differance of 1.94 inches.
I think there is your ABS problem.
Your rear tires are too tall or your fronts are too short.... depending on how you look at it.
Those are only approximations.... I would consult the tire manufacturers site and compare over all tire height. You might also check the sticky for more info.
If you only just put on new rims and tires on the rear.... and... if you still have the old rims and tires.... slap them back on the rear and see if the ABS problem goes away.... I almost bet it does.
The ABS error problem is that with differant diameters front than rear.... the ABS thinks the wheels are slowing down at differant rates(which they are... they are spining at differant rates for any given speed) and this drives the ABS crazy..... it really has no idea what to do and thus the error lights.
Get you some P275 or P285 for the front.... it will probably fix you up just fine.... only problem maybe you might be higher off the ground than you would like going with a 40 series tire.
Welcome to 4x4 country. (Sorry.... I couldn't resist and the very second you post pics, you will no doubt be told you need to lower the car regaudless of what ratio aspect you run.)
You might be able to run a 285/35 on the front....
then you would have 285/35=99.75mm vs 285/40=114
or you might go to a 275/40 on the front
275/40=110mm vs 285/40=114mm
I think the 275/40 up front would be the best choice.... if it will fit without rubbing.
As for stickout... depends on your offfset... but I think if you have a 56mm offset or near there.... you will be fine.
