15" prostars with 5/16th spacer and i still have to grind?
i just bolted on my 15" prostar 3.5"wide on the front with a 5/16th spacer and they spin alitle then hit the calipher, they dont hit it ALOT but its enough that i cant turn the wheel by hand.
how common is this? is the rim bent?
are some cars that different
are you sure it's not the spacer itself hitting the mount for the caliper. when i first put mine on (same setup) the spacer wasn't centered and it would hit at one point in the revolution. just a thought
No spacers here...but an hour and a half's worth of grinding on each side...![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
And then an hour on each rear one to clear the 15x10's...![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I still taste and smell metallic dust....lol.
