HP Evo owners come inside.... questions!
Hub centric rings can be found cheap on ebay. I got a set for $12. Even though the wheels are torqued down there is some slight movement of the wheel and some vibration. I had that issue with my daily driver. Adding the rings helped limit the vibration and the wheel makes better contact with the hub.
yea. well first off, for the few comments above about a 295/305 tire.... in my first post it says they will be widened. As for the widening. i was making this thread out of curiosity to see how these wheels fit in the wheel well as i have no idea on the offsets of them. If they come with an offset already that sits them out closer to the lip, no problem widening them a little. If they dont sit out far enough, but a little. BFH is no problem, if they sit in too much, i could always run a small spacer or look into different wheels. I still havent found anywhere to buy these wheels, atm the option again of widening my current wheels is coming to mind...
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
