305-30-19 ps2's
Old Nov 27, 2007 | 08:14 PM
flynbya2's Avatar
Default 305-30-19 ps2's
I have two pilot sport ps2's.
One has been plugged and patched from the inside (patch not near sidewall),the other has a gouge out of the lip protector,about 1" in length
They have between 7-8/32's tread depth left
Bought them for my car but never installed,money tight right now
Looking for XXX OBOplus whatever fees apply,this is less than half price for lots of fine tread
$325 OBO +yada,yada,yada..
Old Nov 27, 2007 | 08:15 PM
flynbya2's Avatar
These have 8/32's across the outer two valleys,and 7/32's on the inner valley on both tires.I am not sure,but I want to say even wear as they are both wearing the same........could there be a little less tread on the inside originally?
I say that because you can get a MUCH smaller reading in one of the smaller valleys on the edge.But there is still plenty 'O tread
Here's the chunk out of the other lip protector:
Old Nov 27, 2007 | 08:19 PM
flynbya2's Avatar
As I read this is see that it appears I am saying the two outside grooves are 8 and the middle is 7.That is not what I meant to say
The two valleys on one side of the tire measure 8mm,the one on the other side measures 7mm
But both tires the same...
Old Nov 28, 2007 | 12:04 PM
flynbya2's Avatar
rubba
Old Dec 7, 2007 | 01:44 PM
flynbya2's Avatar
Don't be skeered
Old Dec 7, 2007 | 05:25 PM
sammyb's Avatar
i thought about it but I am going to get the nitto's. I just want new stuff. I know these tires are bad *** but for $150 more I get new ones. thanks for the offer.
Old Jan 29, 2008 | 12:57 PM
flynbya2's Avatar
Heck, for 300 more you can get a full set of veredestein's!
Apples and oranges though
TTT with a price reduction
$ 350 OBO + applicable fees and costs!!!
Let's move these out!!! I can only go so low fellas!!
Old Jan 30, 2008 | 12:35 PM
flynbya2's Avatar
TTT again
Old Jan 30, 2008 | 01:45 PM
Stang's Bane's Avatar
The main reason the inner tread would be more shallow than the outer is overinflation.
Not a problem, just thought I would point that out.
Old Jan 30, 2008 | 04:20 PM
flynbya2's Avatar
Not exactly what I meant to say,here I tried to clear it up.
Above here is a better explanation,you can see 3 deep grooves on the tire,then about an 1-1/2" infrom the edge a smaller jagged groove.That groove you can get a much smaller reading(maybe 6 or so off the top of my head,I don't remember).The next large groove which is nearer the center of the tire is the 7.But the other two,one of which is also near the center of the tire,are both 8's.
I don't think there was an overinflation issue with these tires.Even if there was,there is still well over 80% tread left,as they come new with 9/32"
Old Jan 31, 2008 | 05:53 PM
flynbya2's Avatar
Great tires here
Old Feb 2, 2008 | 12:37 PM
flynbya2's Avatar
TTT again
Old Feb 9, 2008 | 12:34 PM
flynbya2's Avatar
Bump^^^
Old Feb 15, 2008 | 12:18 PM
flynbya2's Avatar
Good rubber/cheap price= good deal
Old Feb 15, 2008 | 12:39 PM
ezekielta's Avatar
Too bad I only have 9.5 wide rims or they would be mine.
Old Feb 15, 2008 | 12:43 PM
flynbya2's Avatar
Yep,
According to Michelin website 10.5"-11.5" rim
Thanks for the bump
Old Feb 22, 2008 | 11:15 AM
flynbya2's Avatar
New lowered price $325 + shipping
