Summit Star Wheel
Old Jan 17, 2008 | 07:34 PM
TFRO's Avatar
Default Summit Star Wheel
Can anybody give me a part # for these rims in a 15 X 10 and a 15 X 4. I want to order a set but cant figure out the Backspacing, everybody says use a 7.5 bs and they only show up to a 4.5bs. Any help please also bs for the 15 X 4. Thanks
Old Jan 17, 2008 | 08:34 PM
Camaro396's Avatar
Im pretty sure only the 15x8 summit stars will work. I dont think anyone has used a 15x10 summit star as they dont come with enough backspace.
Old Jan 17, 2008 | 10:25 PM
1CAMWNDR's Avatar
Yeah, you can only get the 15X8 with 5.5 bs unless you have a narrowed rearend.
Old Jan 18, 2008 | 12:01 AM
SYon22s's Avatar
i'm in the process of putting some on my 98Z, i've got new pads and new drilled and slotted rotors so i've grinded a little up front cause i don't want to run a spacer, the rears fit with very little grinding, i haven't got the tires mounted yet, i was just fitting them right now, i will get them mounted saturday and i'll post some pics, nice wheel for the price, 15x4 front w/165-80-15 tire, 15x8 rear w/5.5" BS...275-50-15 MT drag radial...oh yeah BS for the 15x4 is 1.75"
part# for 15x8 5.5" BS....sum-521-5862PS
part# for 15x4 1.75" BS...sum-521-5461PS
Old Jan 18, 2008 | 08:43 PM
TFRO's Avatar
Thanks for the input.
Old Jan 18, 2008 | 09:45 PM
jetlag's Avatar
https://ls1tech.com/forums/wheels-tires/839986-summit-fake-prostars.html
Old Jan 19, 2008 | 01:38 PM
z28berryhill's Avatar
i like em !1
Old Jan 19, 2008 | 02:30 PM
SYon22s's Avatar
Old Jan 20, 2008 | 09:48 AM
TFRO's Avatar
looks good ordered my tires yesterday and my wheels next weekend.
Old Jan 21, 2008 | 04:15 AM
88monte's Avatar
liqour enthusiest
does anyone know if you can use shank style lug nuts with these wheels like the welds?
Old Jan 21, 2008 | 09:11 AM
Photochop's Avatar
I kinda doubt it. The holes for the lugs are recessed into the wheel and have the 60* conical seat to them. They do make a conical style lug that has as slight shank on it that could be used, they cost quite a bit more than the regular acorns though.
Old Jan 21, 2008 | 09:44 AM
88monte's Avatar
liqour enthusiest
i have longer wheel studs on my car, so i didnt want them looking funny. guess ill just stick with the welds
Old Jan 21, 2008 | 10:39 AM
Photochop's Avatar
You could run a lugnut similar to this...
Thats what I was planning on running with longer studs, just install them with the deep narrow socket, should work fine.
Old Jan 21, 2008 | 04:23 PM
h.o.ls1's Avatar
huh...i bought a set of the 15x8s for my car and couldnt get them to work unless they stuck out like an inch or two on both sides...i dont like driving a dirttrack car. well i had to return the rears and go with pro stars which was a way better idea beings the summit stars weigh a ton..
Old Jan 21, 2008 | 06:24 PM
jetlag's Avatar
I used my stock lugnuts.
Old Jan 22, 2008 | 01:51 AM
LT1Z/28's Avatar
Originally Posted by SYon22s
Man that thing looks good!
Old Jan 22, 2008 | 08:37 AM
stroked_408's Avatar
i like it, very nice
Old Jan 22, 2008 | 09:04 AM
95civic2005's Avatar
How does your car hook with those rear tires? Also how much hp are you making?
Old Jan 22, 2008 | 09:29 AM
Photochop's Avatar
Not to ***** the post, but my car had the same rear wheels/tires on it last season and it made 422 rwhp and would dead hook on those tires. With my puny 3500 converter and 3.42s with an MS3 cam and ported TEA heads it would cut consistent high 1.7 60's on the footbrake launching off idle.
Old Jan 22, 2008 | 09:32 AM
wg871's Avatar
I didnt think they sold the summit stars with the right backspacing for a f-body. I guess ill order a set
