New Rim is leaking
Old Feb 4, 2008 | 10:08 PM
BigT2002's Avatar
Default New Rim is leaking
Just put on my gorgeous Aero's and I noticed one of my rear tires was a little low on air about a week after I put them on. Took it over to the tire/wheel shop that put them on and had em check the tire for any punctures. Discovered pretty much behind every spoke it was bubbling. We took it out of the water and sprayed some water on it, and my worst fears were confirmed. I've tried getting with iForge to see if there is anything we can do because I can't honestly say I've ever heard of a rim leaking air like that before.
In the event, assistance cannot be had because of how long its been after the sale (I bought them while I was in Iraq) what would my options be to fix it up so the rim stops leaking?
Thanks guys
Old Feb 4, 2008 | 10:32 PM
sammyb's Avatar
well all rims come with a manufactures defects, thats a defect, the installer couldn't make that happen. I would get with iforged and make them own up and get a new set, all the money you pay for them they should come with your own little pit crew to clean them to. lol
Old Feb 4, 2008 | 10:37 PM
BigT2002's Avatar
thanks man!
Old Feb 4, 2008 | 11:13 PM
Nine Ball's Avatar
LS1Tech Co-Founder
They are 3-piece wheels, the leaking is probably just from the silicone sealer that is used between the two outer hoops when they are bolted together.
Take the tires off, then disassemble the wheels. Apply some better (and use generous amounts) of high temp RTV silicone to reseal them. Get the bolt torque specs from iForged.
I'd try to call them anyways. Explain you were in Iraq and just got them mounted. Maybe they will reseal them for you, since it is rare that they leak.
Old Feb 4, 2008 | 11:16 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
WOW..lotta work for amount of money paid...is this common...I HAVE NEVER heard of it. Then again..most fancy-pants stuff is just that...I like simple better.
Old Feb 4, 2008 | 11:22 PM
BigT2002's Avatar
thanks Tony
Old Feb 4, 2008 | 11:30 PM
NHRAMAN's Avatar
Exclamation
Originally Posted by BigT2002
thanks Tony
I would contact them first myself.....
Old Feb 4, 2008 | 11:55 PM
Kingc8r's Avatar
Yea for the price you pay for those wheels they better...let us know what happens.
On a side note this is the first time I've heard of this happening
Old Feb 5, 2008 | 03:42 AM
3pnt4maro's Avatar
Yeah definitely keep us updated...I was looking into them for my next set of wheels and would like to know how they handle this problem before I shell out some serious money
Old Feb 5, 2008 | 08:07 AM
Nine Ball's Avatar
LS1Tech Co-Founder
BTW, iForged also makes 2-piece wheels that look identical, weigh about the same, and cost less. No silicone sealer either.
Leaking sealer is very rare. Sometimes the tire installers scratch it with those pry bars when mounting a tire. Sometimes it is applied wrong, but that is less likely.
Old Feb 5, 2008 | 08:16 AM
DopeFedZ's Avatar
Like Tony said just have the tire removed take the wheel apart and reseal it. I had to do that to two of my CCW's. You are gonna spend more money shipping it back instead of paying $10 to have the tire removed and mounted again.
