weld magnum/alumastar valve stem?
WTF?
weld drills the hole .562 on their rear wheels.
all valve stems are .453 or .625.
i call weld, they dont make a valve stem to fit their wheels. jessica says noone does. she advised me to drill my wheel out to .625.
so odd.
pure BS, IMO.
why do they even drill a hole in it?
does anyone know of a trick, or a valve stem out there that weld doesnt know about?
drilling the wheel isnt an issue, but i have to buy valve stems anyway.
so odd.
pure BS, IMO.
We drill ours to fit standard small ~7/16" seals, for the folks who use tubes, you drill them out to the larger diameter. Stems usually come with two adapter seals if you want to switch back to a tubless setup. Just drill it to 5/8". If there was no hole drilled to begin with...many may have a tough time starting a new hole possibly going to close to the bead surface making it tough to mount a tire or even go too close to the shells center.
Very nice high quality wheels that you purchased . In the future or for others interested, our designs are generally less expensive and can be built lighter. Our backspace options are far greater...easily going to 8" on a 10" wheel depending on the design.
i love the look of the magnums, and its the only reason i purchased them.
comming from a wheel guy.....i bet you wouldnt drill a hole in your wheel that didnt fit anything.
its lil things like this, along with waiting for them since november, that really get me.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
TJ,
Totally understood. The wheels you have are a VERY nice high-quality wheel and from a comparison...is very close. I tell folks all the time, if you like the way one of their high-end wheels look, get them...you won't be disatisfied with the results and quality of the wheels.
I'm not sure what to say about the valve stem holes, it is odd they are drilled to the size you suggested. It's a very minor issue though for the nice wheels you have.
Regarding the comments to our Bogart products, I only want others to see comparisons...since I'm not representing weld...I need to at least make a comparison to our Bogarts for others. It's refreshing to point out that our wheels are not the most expensive wheels on the market by any means. Ours are even custom built to the application.
