mt 315/35r17
Old Feb 26, 2008 | 01:49 PM
formula4437's Avatar
Default mt 315/35r17
will Torq-Thrust II 17x11 and mt e/t streets 315/35r17 fit on my rear without any mods
Old Feb 26, 2008 | 09:14 PM
anybody know?
Old Feb 26, 2008 | 09:20 PM
BJSS25's Avatar
First thing is your car lowered, if not you should be fine if you have a adjustable panhard bar. If lowered you will definitely need a adjustable panhard bar and BFH mod on inner fenders, and depending on how low the car is, you need to roll the lip of your fenders. Hope this helps.
Old Feb 26, 2008 | 09:34 PM
BOLO's Avatar
I used to run AR TT2 17x11 w/BFG 315/35 drag radials.
Just a little BFH modification inside the wheelwell was all that was needed.
Old Feb 26, 2008 | 09:37 PM
my car is a 99 formula that is not lowered
Old Feb 26, 2008 | 10:06 PM
jetlag's Avatar
My car is lowered on Eibach Sportlines with BFG 315/35/17s and I didn't have to beat any wheel wells or roll the fenders..
Old Feb 26, 2008 | 10:09 PM
wichoms4's Avatar
i have those tires. i used spacers. they will rub on turns w/out spacers. very good tire. they hook realy good.
Old Feb 26, 2008 | 11:28 PM
2002camaross35th's Avatar
What size of a spacer did you put??? Also intrested in running the 315/35/17 out back
Old Feb 27, 2008 | 12:55 AM
1bdbrd's Avatar
I had that exact setup on my 94 (sold now) and drove around on them some. When I took them off I noticed some markings on the inner fenders from where they were rubbing. Car is stock LT1 height (a little lower than ls1s) with no inner fender mods. Some BFH work and it would have been fine at that height.
