Are these the right lugs and studs?
Old Mar 4, 2008 | 11:13 PM
Kurt's Avatar
Default Are these the right lugs and studs?
I'll be buying some Pro Stars soon, and I'm going to go ahead and upgrade the studs. Are these the right ARP studs? Do I need 3.5" (PN 100-7713) or will 2.5" (PN 100-7708) be fine? I plan to use 5/16th spacers on the front, no spacer on the rear.
These Lug Nuts?
Part Number: Weld 601-1422
Lug Nut Seat Style: Shank
Thread Size: 12mm x 1.50 RH
Shank Length (in): 1.380 in.
Shank Diameter (in): 0.687 in.
Overall Length (in): 2.020 in.
Old Mar 5, 2008 | 12:39 PM
Kurt's Avatar
Anyone?
Old Mar 5, 2008 | 05:38 PM
Dmoney's Avatar
I went with the 7708 2.5's..........
Old Mar 5, 2008 | 05:41 PM
GregWS6&z28's Avatar
get the 7708
Old Mar 5, 2008 | 07:57 PM
Kurt's Avatar
Will they be long enough to pass NHRA tech?
Old Mar 5, 2008 | 08:54 PM
to pass NHRA tech, dont the ends have to be open so they can see the threads?
Old Mar 5, 2008 | 09:27 PM
Kurt's Avatar
I will be using open ended lug nuts, but I thought I heard that they must stick out past the end of the nut, but I'm not sure.
Old Mar 5, 2008 | 09:55 PM
not sure about that
