18x10.5 Wheels Fit with 61, 56, or 65 Offset?
I know the afswheels (Z06 chrome) will fit front and rear Camaros. They are 18x9.5 with 56mm offset.
I found these other replicas on Tirerack.com in the following measurements:
Size Price
18X10.55-120.65HC61C $282.00 61mm offset, chrome
18X9.5 5-120.65HC65C $269.00 65mm offset, chrome
18X9.5 5-120.65HC50C $269.00 50mm offset, chrome (this is the size they show that will fit Z28).
Will 285/35/18's fit on the front?
I was wanting to run the GForce drag radials rear, size either 275/35/18 or 295/35/18 if they'll fit.
Size Price
Re: 18x10.5 Wheels Fit with 61, 56, or 65 Offset?
50 mm is perfect. The large the number the deeper the wheel sits in the wheel well. 61mm and 65mm will look VERY stupid!
275/35ZR18 is the same OD as the stock tire, and the widest I'd go for a front tire.
I've already clearanced (bump stop, fender rolled, etc.) for the 11's and 315's I have now...
