OEM C6 Wheel fitment Issues, Help!
Hey BandDirector, what suspension do you have in there? I'm picking up a set of C6's and know I'm gonna have to drop my ride height... Also, I have an SS, will aftermarket springs make a difference for Z28 and SS? I think I only wanna go 1" max, due to the SLP LT's clearance issues..........lol
Thanks, Matt.
Thanks, Matt.
275/40/17 tire = 25.66" tall
275/30/19 = 25.5" tall
285/35/19 = 26.85" tall
So as you can see, if you stay with the stock C6 285/35/19 tire, it's over an inch taller than the stock size which will throw the speedo off and will fill the wheel well up a little more which MIGHT cause minor rubbing. However, most guys that run the 1.25" spacer on the 285/35/19 don't report rubbing issues.
Well 'm lowered on Sportlines, just purchased a set of OEM C6 19x10's, i know i have to purchase 1.25" spacers, but idk that just sounds TO much of a spacer. i dont want my wheel to be poking out!! SO u think an 1" will do? or 1.25" doesnt poke out!
I see it on ur CAmaro, but i have a TA..
Thanks!
Thanks!
That's why I got the 1" spacer. The backspacing on the C6 wheels is around an inch less than the F-bodies, so the spacer will basically make the wheel stick out the same amount as the stock wheels. If you do a 1" spacer you'll have to cut down your wheel studs around a 1/4" on the back.
I have the OEM C6 wheels and although on the back it is close to the inner bump stop or whatever it doesn't touch, however I'm in the process of rebuilding my motor so haven't drove it yet like this. But I also want my wheels to have a more flush look with the fender and I believe the 1.25" spacer will be way to big.....what's this talk about cutting the studs if you use a spacer? If you put a spacer in wouldn't your studs be too short?
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I have the OEM C6 wheels and although on the back it is close to the inner bump stop or whatever it doesn't touch, however I'm in the process of rebuilding my motor so haven't drove it yet like this. But I also want my wheels to have a more flush look with the fender and I believe the 1.25" spacer will be way to big.....what's this talk about cutting the studs if you use a spacer? If you put a spacer in wouldn't your studs be too short?![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
I know my car is a Camaro, but the stock C6 rims fit VERY nice and flush with the 1.25" spacers and I have no rubbing issues at all and no BFH mod either. Just bolt on the spacers and go with 275/30/19 tires.
