conflicting information, HELP?!
Old Apr 7, 2008 | 12:00 PM
kail's Avatar
Default conflicting information, HELP?!
alright, i posted awhile back asking if an 18x8.5 rim in the front with a 35 mm offset on a lowered car (vogtland springs 1.5 inches) would be ok, and i got a hearty yes. i purchased the rims, and now some ive started hearing i need a 38 mm offset or more. before i mount tires, i was wondering, would the 35 mm offset be ok, or do i need a larger offset. I really cant afford to take a loss on the rims and tires, so i need to know before i mount anything. please let me know.
Old Apr 7, 2008 | 12:03 PM
95GreenZ28's Avatar
Mounting these on a TA or Camaro?
Old Apr 7, 2008 | 12:04 PM
kail's Avatar
2000 Ta
Old Apr 7, 2008 | 12:07 PM
95GreenZ28's Avatar
I think they will be ok. Let me see what my bros front offset is and I will let ya know. Are you lowered at all?
Old Apr 7, 2008 | 12:12 PM
kail's Avatar
1.5 inches on vogtland springs. dude if you can find this out your my hero. if your info is right, im not above a cash bounty at this point
Old Apr 7, 2008 | 12:13 PM
95GreenZ28's Avatar
They should be fine. You may have to run a 245 tire to make sure you dont rub. My bro has AR rebels and they have a lot less of an offset than that and they clear fine and dont stick out past the fender line
Old Apr 7, 2008 | 12:15 PM
95GreenZ28's Avatar
What rims are you looking at installing?
Old Apr 7, 2008 | 12:25 PM
kail's Avatar
a set of ruff racing 278
18x8.5 with a 35 mm offset in front
18x9.5 with a 45 mm offset in rear
i dont mind em stickin out a little in the rear lol, and as long as they dont rub, ill count it as a win at this point
your bro is lowered too?
Old Apr 7, 2008 | 12:29 PM
95GreenZ28's Avatar
https://ls1tech.com/forums/showthrea...fito+fith+ruff
Look at post number 8. He has them and they fit just fine
Old Apr 7, 2008 | 12:41 PM
kail's Avatar
im lookin for tires tonight, thanks man. ive been freakin out over this like you wouldnt believe.
These are good for a lowered car ?
Old Apr 7, 2008 | 01:00 PM
No Juice's Avatar
Here check this out. Its lowered about an inch or slightly more in the front with the same wheels you are looking at with a 255/40 tire up front and 295/35 out back and they don't rub.
https://ls1tech.com/forums/wheels-tires/897453-finally-som-new-shoes.html
Old Apr 7, 2008 | 01:23 PM
caliswangin916's Avatar
you should be fine. i have 19x8.5 +38 up front with a 245/35/19 tire and a 2" drop up front. with these tires, the fender is about 25" from the ground and i could get another 1" of lowering and they would be fine. there is about another 1" more room towards the inside as well. 3mm is nothing. i would use a 245/35/18 for your fronts. no need for a wider width and a 40 series would look too tall.
i think your back is very close to rubbing on a 275 tire if you're tucking any of the tire. unless you have an adjustable panhard and roll the fender.
Old Apr 7, 2008 | 01:47 PM
Xsta Z 28's Avatar
I don't see an issue . . .
Old Apr 7, 2008 | 02:11 PM
Blakbird24's Avatar
Restricted User
How about proof?
That's an 18x8.5 (35mm offset) with a 275/35/18...fits with plenty of room to spare. Car is lowered on Hotchkis springs.
For the record, don't put a 275 on an 8.5" wheel...it works but it's just not right. I'm switching to 255's in the very near future.
Old Apr 7, 2008 | 04:04 PM
kail's Avatar
point for blackbird...thank you all, ive been freakin out. the sticky said 38, and i had an oh **** moment...
Old Apr 7, 2008 | 04:32 PM
95GreenZ28's Avatar
I was trying to find pics of your car Blakbird Nice ride and I am glad you posted up in here!
Old Apr 14, 2008 | 12:03 PM
kail's Avatar
got the rims, tried to put em on they DO NOT fit on my setup, i guess the springs are just too low....
no tires mounted on em yet, so if anyone wants a set of of ruff racing hyper black 278's 18x8.5 18x9.5
its 660 for the set. im done with this.
Old Apr 14, 2008 | 12:04 PM
kail's Avatar
anyone know a place that sells the 17 inch ruff racing rims? im trying to get somethin that will fit. hell ill even pull an even trade for the 18s at this point.
Old Apr 14, 2008 | 12:46 PM
No Juice's Avatar
How do you know they don't fit if you never mounted the tires?
Old Apr 14, 2008 | 12:47 PM
No Juice's Avatar
Is it 660 shipped?
