There goes another tire!!
I have the WS6 17 inch tires (275-40-17) and I have replaced 3 in 10,000 miles, all on the rear.
Bump stop is in good shape and hose mod out back, but hitting a bump that might be larger, but causes no problems to other cars, just destroys tires. Lots of cars with low-profile tires on the island, you'd just have to be here to understand. The mode of failure is sidewall pinch. I even added a quarter inch of cushion rubber from the pre-existing spacers above the spring to try to alleviate.
Please, not interested in the obvious "why don't you just avoid them" response, Puerto Rico is inundated with these problems. And I'm aware that I probably should've gotten a crappy import. No thank you.
Shocks are all about control.... The car does settle appropriately after an initial deflection input. Now 39k Miles.
How fast & hard are you hitting these holes to make it ruin the tires???
even some cheap tires should last longer than that
