Attention anyone wanting REAR Greg Welds
Old Jul 15, 2008 | 10:03 AM
  #141
Camaro396's Avatar
I don't think so.
Old Jul 16, 2008 | 11:29 AM
  #142
dlove's Avatar
test fitting wheels later today.
Old Jul 16, 2008 | 11:33 AM
  #143
Fast895ohstang's Avatar
i figured you would make the post...ill prolly see ya tonight as we are testing them on an 03 cobra as well to check for irs clearances
Old Jul 16, 2008 | 01:03 PM
  #144
hazard2k's Avatar
could you snap some pics of the wheels? I would like to know how the revision looks as far as the recess goes for mounting the tire.
Old Jul 16, 2008 | 01:06 PM
  #145
dlove's Avatar
yeah thats the plan....
Old Jul 16, 2008 | 01:35 PM
  #146
DopdBrd's Avatar
SWEET!!!! I would like to get some soon... I know that it will probably still be another few months before they do get released but at least we are a little bit closer!
Old Jul 16, 2008 | 01:49 PM
  #147
Dirty 30's Avatar
What size are you test fitting?
Old Jul 16, 2008 | 04:11 PM
  #148
should be redisgned 15x8s and i believe 15x10s
also to Dopdbrd...i am supposed to be going to branson, mo for a big cruise/show deal and mike said i should have my set of 15x3.5s and 15x8s before then which is august 8th
Old Jul 16, 2008 | 07:12 PM
  #149
Ruckus46Gt's Avatar
nice good news my et streets are getting worn dont want to replace want to put street tires on and pick up the rear greg welds finally
Old Jul 16, 2008 | 07:25 PM
  #150
1BADTALS1's Avatar
sweet i can't wait till these come out...
just means the for sale section will be flooded with all the other brands...
don't mind a little grinding if i can get a set cheap..
and does anybody know what the price will be for the greg welds once they are done??
Old Jul 16, 2008 | 11:35 PM
  #151
ls1pwrdss's Avatar
get the damm things mounted already. i cant take no more
Old Jul 16, 2008 | 11:57 PM
  #152
Cobras with IRS No go...
Cobras bullitts machs good to go
Ls1s will still need very slight grinding to fit...dlove should be posting pics of the areas that will require...it will be very slight grinding..im sure lt1s will be fine
Old Jul 17, 2008 | 12:01 AM
  #153
dlove's Avatar
good and bad. tested the 15x8's on ls1's. a ton more room but still not perfect. With about the same amount of grinding as prostars but more than summit stars they can be made to fit. Before they weren't even close.
They also currently only had the 15x10 in a 6.5 BS. The 7.5 is on the way though! The 6.5 didnt want to fit either. They said the 15x10 with the 7.5 BS should fit with NO problem at all ,due to the wheel's drop center design being different. Once those come in I will test them as well.
lt1's should be good to go. Might need slight grinding.
Sorry currently no pics.
They are going to try and do some final adjustments if they can and then get the wheels coming. Give or take 30 days till they are out.
Old Jul 17, 2008 | 08:04 AM
  #154
hazard2k's Avatar
Good enough news for me! Did you happen to take any pics?
Old Jul 17, 2008 | 08:15 AM
  #155
i know dlove has some but he prolly needs to upload them still. the change to the 7.5BS wheel is that you mount the tires from the rear allowing 14" of clearance on a 15" wheel vs on the original 15x8s there was around 12. now they are close to 13". mike was gonna try to take a slight amount of angle back out of the drop center to get a little bit more room
Old Jul 17, 2008 | 08:56 AM
  #156
dlove's Avatar
should have some lt1 cars later today to test on as well
Old Jul 17, 2008 | 08:59 AM
  #157
chevrunner21's Avatar
so the summit stars take more or less grinding? pretty much another dud than on a 15" back wheel that needs no modification to fit on ls1 cars? is the 15x10 with this new 7.5" bs supposed to be the magic wheel? I've thought about 15's but cant justify spendin the money on bogarts and just dont want to grind my brakes(like many others) i guess ill have to wait and keep reading.
Old Jul 17, 2008 | 09:31 AM
  #158
DopdBrd's Avatar
SAWEEETT!!!!!! Hurry up and get these things out. I need my 15x10 rears!!! LOL
Old Jul 17, 2008 | 09:44 AM
  #159
blackz6sp's Avatar
Yep waitin on the 15x10's for an LT1 here!!!!!!!!!
Old Jul 17, 2008 | 10:03 AM
  #160
dlove's Avatar
15x10 with the 7.5 BS should be a near direct fit for ls1's. In about 2 weeks I can confirm that.
