Mickey Thompson gave me some junk ET Street Radials
Honestly, that could be a portion of your problem. I run mine no more than 25 psi when driving, usually I run at 21. AT the track I drop them to 15-16 psi. I don't know what M/T recommends, but that is what I have found out to have the most even wear when street driving and best traction at the track.
When tires are over inflated, they do not put optimal tire patch on the ground, it tends to "Bubble up" wearing down the center excessively. Also, when your only riding on a small (Center) portion of your tire, there is a greater load created on the part that is touching the ground. More weight per square inch of contact patch. More load = more heat, and heat could essentially wear tires quicker.
Thats just my opinion.
what psi were you running in the tires? I had a set do that to me last year, They were overinflated do to a falty tire pressure gauge. It would read 20 psi lower than it was. ex. ( if there was 40 lbs in the tire, the gauge would read 20) And my tires did the same thing those did. Very well could be just a bad batch, but that is Exactly what happened to me! I was pissed.
I said the same thing... he responded (in another post) "I posted as many times as I needed to" or something of that nature...
He probably did a smoke show and is pissed that his tires are worthless now
#34
#35
I'll rule out the defective issue. Since your friend has purchased his set at the same time and his are apparantly fine (and he is running a spool which can be harder then a posi setup), they probably came from the same batch. So I don't think it would be a defect that you're considering. The chances that you happen to get two of the defective tires when you and your buddy purchased wheels...is small.
I would look elsewhere as possibly your driving habbits, road surface usage, tire pressure, rear-end not aligned with front wheels etc. Miles used does impact tire life, but importantly actual usage during those miles that were run. I think this is probably where the problem may lie.
Tires are consumables, they need replaced. I'd be more angry with the price of gas that it costs you to go those 800 future miles.
#38
sorry guys... just pissed and trying to post it so multiple people saw it!
SJM my buddy has 275/60/15 tires... So I would highly doubt they came from the same batch... Although he did buy them at the same time as me!
#39
I've seen many sets do that, right from the time they are new.
I think 35 psi might be too much air in them. I run mine 28-30 psi & have a ton of passes & street miles on them & they don't shred like that.
#40
I've had sets do that also and usually they don't hook nearly as good when they are like that!
Never have I had them go that fast thought, especially just leaving black marks driving down the road. How hot is it there currently? Highway driving in the summer seemed to make my tires look like that most of the time.
