325's 50/R15 Issue Need help
I have a 2002 Camaro Z28 with the moser 12 bolt rear. Extended arp studs , Just fabed up the rear to fit the tires , had to grind the calipers some to get them to clear as well.. Finally got them on and there is no scraping at all. The only Issue that im having is the Abs inoper , brake , and asr light comes on at 40 mph? Everytime i shut the car down it goes away when i start it back up. If i roll around less then 40 its fine doesnt go on .....right when i hit 40 mph it throws all three codes at once. Anything in particular that i could do or try ? i mean it kinda pisses me off that it all fits but at 40 this happens.
help me out guys really need this problem to go away thanks
Check with SJM Manufacturing. They make some kit *** ABS delete kits with a line lock. I know I'm getting one in about a week. My Dana does not have the ABS provisions and I will be running 28's on the back with 26's in the front after this weekend.
The above comments are correct. ABS will not operate correctly when it is out of its design parameters. Even if you were to remove the lamp, your brake system will not operate correctly whereas ABS will activate when you probably DON’T want it to increasing braking distances among other problems.
To all folks that are considering different sized tires…Typically when you purchase new rear-ends, no sense in adding ABS options as they will increase costs yet ABS rendered useless on your car.
Our kits remove the entire ABS bracket and modulator with new pre-formed lines. EVERY kit includes an adjustable proportioning valve for front/rear bias adjustment needs. Previously, when your car had ABS, all bias adjustments were made with the modulator. Since ABS is not functioning, the adjustable proportioning valve takes its place.
