16" drag wheels?
I have searched, I use search quiet frequentley, for everything,but i could not find anything.
Do they make a 16 x8 or 16 x10 rear drag wheels? Anyone?
Joe
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I've had some people ask for 16's for the fact they already have tires. I tell them tires are consumables and won't last, wheels do.
We can build direct fit 15" wheels for your car.
Well the main reason in asking is because I really didn't wanna grind the calipers. Yah I don't mind doing it I guess. (you do need to grind for 15's on the rear correct?)
I do want a set of 17 10spokes for the street, but need wheels for a lil street/track action.
It is a pain to swap wheels all the time.
So maybe I'll just run skinnies and DR's full time?
Or do the 17" MT Drag Radials hook at the track?
With how I design our Bogart's, our 15" wheels fit with OEM brakes/calipers/rotors front and rear NO grinding. They should bolt right on.
So if you don't want hassles and want the lightest direct fit 15" wheel, we have the solution for you.
