LED Resistor parallel wiring question
My question is, if i wire in parallel and i do 50 leds with 1 resistor, will that work ok or is it better to have like 1 resistor per 10 leds and have 5 total resistors. i have a resistor calculator program but im not sure if its a good idea. once the project gets going ill post up pics. i bought 200 red leds for the main tail/brake lights and 100 white leds for the turn signals/reverse lights.
We really need the details to say for sure.
Emitted Colour : Red
Lens Color : Water Clear
Forward Voltage (V) : 2.0~2.4
Forward Current (mA):20
View Angle: About 25 degree.
Static Sense:Yes
Luminous Intensity: 15000mcd
http://led.linear1.org/led.wiz
Also, for more knowledge on LEDs check out this site.
http://www.hidplanet.com/forums/
I'm actually in the process of making prototypes for all the different tail lights and 3rd brake lights for all our 4th gens. After I get the prototypes done the way I want then I am going to become a sponsor and start offering my services to do full LED conversions. I'm also going to be doing interiors.
Vbat=14V
Vr(esistor)=11.8V
# of LEDs = 50
Iled=20mA
Vr = Iled * # of LEDs * R
11.8V = 0.020A * 50LEDs * R
R=11.8 ohms (you are correct)
Power = I^2*R = (0.020A*50)^2*11.8ohms = 11.8W
11.8W is a lot of power, you might be able to find 2-3 5W resistors and wire them in parallel but then you need to recalculate your resistor values.
OR.....
to take advantage of your 14.4V battery you could wire 10 strings of LEDs in parallel with each string containing 5 LEDs.
Vf=2.2V*5LEDs = 11V
Vbat=14.4V
Vr=3.4V
Iled=20mA
# of LED strings=10
3.4V = 0.020A * 10strings * R
R=17ohms (1 resistor is not recommended, use one per string)
P=(0.020*10)^2*R = 0.68W (a huge reduction in power) you'll be able to use a few cheap 1/4W resistors in parallel or 2 1/2 watt resistors.
OR to be safe you could run 4 LEDs in each string but 5 should be fine. You just might get a big drop in LED current when you shut off your car because Vr will only be about 1V with 12V on the battery (unless all your LEDs are at 2.4V, then with 5 LEDs per string you would have a Vf=12V and have no current, which might not be good for hazard lights, then youll only get 6mA/LED but you might not care. You could play around with the numbers but the more you put in series, the less current/energy you waste on the resistor. Even if you use 2-3 in each string and 18-25 strings in parallel you would benefit.
Sorry, I didn't get back to this thread before today. Looks like what you need has been posted. Good-luck & let us know how it works out with pics.
