Sound Deadner Install Pics
I have a specification off an eBay seller that says eDead 80 is 0.60 lbs/sq.ft. That would mean 120 sqft would be 72 lbs.
I may go with the RAAMat based on weight alone. It will probably suit my application just fine.
**Went ahead nd ordered 2 rolls of RAAMmat BXT, 3 rolls of Ensolite MLC, and adhesive. Will get pics and results when finished**
Also what is Ensolite MLC and what is it for?
As for cost difference, I'm not sure with all the eDead secret discount codes and what not, but raamat is fair priced in my book.
Ensolite is a closed cell foam that is odor, mold, moisture, etc resistant. You take it and put it on the back of your interior panels with a spray on adhesive to further enhance sound and deaden unwanted noise and rattles.
Straight from the website:
"Ensolite, a very durable, light weight, closed cell foam is the ideal sound absorbing material for automotive applications. Most products sold for this purpose are outrageously expensive leading many DIYers to use inferior materials that do the job, but can’t stand up to your car’s harsh environment. Jute and the open celled foams you can buy in a craft shop absorb moisture, leading to mildew and nasty odors. Some “improvised” solutions even present a fire hazard.
Our Ensolite sheeting is the ideal solution. Very reasonable cost, available in the quantities you need and easy to apply with our spray adhesive."
All of raamaudios products went in/on with ease. The ensolite was easier than I thought, especially for a first timer. As for the raamat, the foil is coated in something and I didn't get cut one time. Peel and stick. Just as simple as that..
Like I said before, I ordered 50 sqft and after what I did last night I still have TONS of material left. I'm hoping that I can make it up to at least the driver seat with what I have left.
I ordered 200 sq ft but so far, I've only managed to use about 145 sq ft. I will probably "double up" my floor board with the remaining amount.
