What should I do?
What I want is full sound from just replacing the doors and sail panel. You know just nice full range of sound without adding a sub. I was wanting to get Kee Audio's "Premium" speaker replacement and add an amp but will the sail panels still put out bass? I want to do whatever it takes to get a nice full range of sound without a sub.
If you really want to change the sound you'll have to replace the head unit and/or amp. You could run an aftermarket 4-channel amp and use crossovers and low-pass filters to get the right balance of sound from the door components and the sail panel subs. That combination would probably be your best bet if you don't want a separate sub.
That does not make them perfect. They are great speakers, but IMO they are not a replacement for a sub. However, they are better than the CDT hands down and they are more likely to satisfy people without a sub.
You will pay more for Rainbows though (as compared to CDT).
I wish i knew this before i went and bought 2 amps. the sony amp alone would have done great
WhiteBird00
if ur not in a hury u can wait until i get my set up done and il deff give u an answer
and i still want to keep the weight light.
