Slow windows fix
Old Jan 17, 2009 | 10:43 PM
Intercooler2's Avatar
Default Slow windows fix
Shortly after I got my car I had to do both motors. Not long after I did the work I noticed a couple of times the windows went up slow. I pulled the switch in the handle out and messed with the wires a little and they both went up noticeably faster. So it is pretty easy to see they have a power issue maybe a ground. I was thinking about hot-wiring it or just running a ground. Where would be the best place to get good juice rather than going up to the battery for both doors? Could it be just the ground? Anyone ever use a multimeter on the wiring to see what voltages we have there and if just moving the wires around gives an increase?
Old Jan 17, 2009 | 11:20 PM
7th Darkness's Avatar
Do a search for autotrix
Old Jan 18, 2009 | 12:00 AM
Saw that a couple of posts down and read through it. I'm thinking it can be less complicated by running to the fuse box or grounds closer and only one or two wires. Was searching for what research was done to figure out the issue.
Old Jan 18, 2009 | 02:52 AM
x2jesse1x's Avatar
autotrix
Old Jan 20, 2009 | 12:47 AM
nhra-trans-am's Avatar
Moderator
I installed a kit on my car and now my window does not work at all. The window was working fine before and was just a little slow. I have checked the wiring and everything is good. This is the 3rd kit i have installed so I know what I am doing. I tried emailing and PMing autotrix, but have gotton no response...so much for good customer service. I guess this kit was just a waste of my money...I wont be buying another.
Old Jan 20, 2009 | 10:03 AM
OhOneWS6's Avatar
For years I have seen noting but good reviews for the autotrix kit. Yours is the first negative review. You must have had success with them in the past since this is the 3rd one you have installed. Were the other two for you or for someone else?
To the OP, The autotrix fix is the way to go. You may have to put a replacement motor in as well but still use the autotrix kit so the new motor doesn't fail prematurely.
Old Jan 20, 2009 | 10:12 AM
WhiteBird00's Avatar
Ungrounded Moderator
The Autotrix kit consists of some wire and a couple of relays. It's nothing you couldn't do yourself but for the price it's much more convenient to buy the kit.
That being said, my point is that there really isn't much that can go wrong. The only point of failure in the kit is the relays and they are easy to test. Otherwise it comes down to installation mistakes or blown fuses. If you're so sure you know what you're doing then what have you done to diagnose the problem? Have you checked the fuses? Have you tested the relays?
Old Jan 20, 2009 | 10:39 PM
Moderator
The other 2 were for a friend's car and for my other car.
I have checked the fuses and relays and they are both fine. The wiring is exactly like the diagram. I am now in contact with Autotrix to try and diagnose the problem.
EDIT...turns out there was a problem with the window motor, not the kit. The Autotrix kit works fine.
