What wires to splice into for Autometer gauges?
I have an electric water temp and an electric tranny temp gauge from Autometer on the way. I would really appreciate it if someone could tell me what wires I need to splice into for these. Thanks a lot!
You dont splice into anything, you have to install senders for both, which is very easy. For the tranny, replace the drain plug with the sender. For the water temp, remove the plug above the starter in the block and put the sener there. For this spot, you need a M16x1.5 adapter
