Having Problems Reprogramming Transmitter!!
Old Mar 10, 2009 | 12:50 AM
JacobK's Avatar
Default Having Problems Reprogramming Transmitter!!
Ok heres my problem, my old key fob broke, so i lucked out and have a friend that works at the local chevy dealer, he got me 3 key fobs and they all look IDENTICAL to mine thats broke, now the numbers on the back are different, so i dont know if thats why im having a problem or not...But here is whats happening, i cycle my car 3 times, the driver door locks and unlocks but the passenger side door just locks it doesnt unlock, and neither does my hatch. So anyways, i tried just holding the lock and unlock buttons down anyways and of course nothing happened, so now im stuck, what should i do, i dont wanna pay to have this reprogrammed, so any advice would be appreciated...Oh ya heres the different part numbers in case that helps
My transmitter that did work - 16245100-29
the new ones are 10443537...
PLease help me guys!!!!
Old Mar 10, 2009 | 01:41 AM
JacobK's Avatar
Another thing i forgot to mention which i dont know if it makes a difference or not is my security light is on...I dunno if that has ANYTHING to do with anything buy i figured id throw that out there.
Old Mar 10, 2009 | 02:41 AM
98CamZ28's Avatar
Heh, I tried the same thing today but after cycling the ignition, I didn't hear anything happen or have the hatch open. I did pull the radio fuse (I think, no diagram at the time, but I believe the 10 amp to the far left) and tried it again but no luck.
I also have the security light on as well, hmmmm. Hopefully we get an answer
Old Mar 10, 2009 | 10:43 AM
JacobK's Avatar
TTT..anyone have any advice???
Old Mar 10, 2009 | 12:55 PM
2001NBMZ28's Avatar
10443537 is the wrong remote, looks the same but for newer cars. Search the fccid# on remotes here: http://autotechs.com/fcc/fccidsearch.htm and it'll tell you the PN also.
Old Mar 10, 2009 | 01:40 PM
2001NBMZ28's Avatar
98CAMZ28 try programming again, think you got the wrong fuse. #17 radio fuse is a 15 AMP, lower right.
Old Mar 10, 2009 | 03:16 PM
JacobK's Avatar
well that really sucks...i thought as long as they were somewhat the same it should be able to program?
Old Mar 10, 2009 | 03:53 PM
Nova5's Avatar
GM number on the rear has to match for the car to accept them.
Old Mar 10, 2009 | 04:01 PM
2001NBMZ28's Avatar
Give your buddy the PN of your original remote, they were widely used. Maybe he can find one or two.
Old Mar 10, 2009 | 06:07 PM
JacobK's Avatar
well heres my other problem then, how come when i try to cycle the car, the driver door locks and unlocks, but the passenger side will lock but wont unlock, and then the hatch doesnt open...
Old Mar 10, 2009 | 06:42 PM
2001NBMZ28's Avatar
If it worked fine before with the correct remote, it should with another with the same fccid/PN after reprogramming it.
