Wiring system
Old Mar 15, 2009 | 12:32 PM
Havoc54's Avatar
Default Wiring system
Does this look correct to achieve a 2 ohm load for the sub woofers.
The amp pushes 1200 watts at 2 ohms and each sub woofer handles 600 watts rms.
Old Mar 15, 2009 | 02:55 PM
M-ManLA's Avatar
The biggest thing is how you wire the subs to the amp. I explain this on another post on LS1.com
http://www.ls1.com/forums/showthread.php?t=105824
Old Mar 15, 2009 | 03:21 PM
99Bluz28's Avatar
Looks good! If you subs are dual 2ohm.
http://www.rockfordfosgate.com/rftec...hmDVC_2ohm.gif
Old Mar 15, 2009 | 03:24 PM
99Bluz28's Avatar
Question
Why do you have a remote wire running to the Cap?
Old Mar 15, 2009 | 03:44 PM
Engine_HP's Avatar
need specs of ur subs
Old Mar 15, 2009 | 04:19 PM
M-ManLA's Avatar
Yea why do you have the remote lead on the cap? You only need it on the amps.
Old Mar 15, 2009 | 05:44 PM
Havoc54's Avatar
The capacitor I have has a remote in. If you dont run a remote wire to it then it wont turn on.
Old Mar 15, 2009 | 05:48 PM
Havoc54's Avatar
Alright
Amp- Kenwood eXcelon KAC-X1R
# 2400 watt Monoblock amplifier
# Power Handling:
* Peak Power: 2400 watts x1
* RMS Power:
o 600 watts x 1 @ 4 ohms
o 1200 watts x 1 @ 2 ohms
# ISF (Infrasonic filter) Switch
# B.R.F. (Band Reject Filter) FREQUENCY control
# Accepts 4 Gauge Wiring
# Slave Amplifier Output
# Digital Read-Out Display
# Remote Input (Optional)
# Fuse Rating: 25A x 3
# Dimensions: 13-3/8" L x 8-7/8" W x 2-3/8" H
Subs- Kenwood eXcelon KFC-XW1224D
# 12" Dual 4 Ohms eXcelon Series Subwoofer
# Power Handling:
* Peak: 2000 watts
* RMS: 600 watts
# Impedance: Dual 4 ohms
# Carbon glass fiber cone woofer
# Rubber surround
# One-side terminals
# Rubber magnet cover
# Dual magnet drive
# Super linear spider
# Push terminals
# Removable gasket
# Heat transfer structure design
# Dual 4 ohms voice coil
# Frequency response: 25-800 Hz
# Sensitivity: 91 dB
Old Mar 15, 2009 | 08:11 PM
M-ManLA's Avatar
Never seen one like that. What model is it?
Old Mar 15, 2009 | 09:09 PM
Engine_HP's Avatar
Bro ull never get the 2ohm load with a pair of DVC 4 ohms subwoofer.
heres what u can do:
the pic shows a 4ohm load.
hope that helps
Old Mar 15, 2009 | 11:39 PM
Havoc54's Avatar
I can get the same subwoofer but in a dual 2 ohm instead of a dual 4 ohm. Could I achieve a 2ohm load that way?
Old Mar 16, 2009 | 01:25 AM
Engine_HP's Avatar
with a pair of DVC 2ohm u can wire to get a 0.5, 2 and 8 ohm load.
bro get urself a Pocket Digital Multi Meter Tester Ohm DC AC Volt Amps $10 shipped from ebay to measure ur ohm load and to make sure everything has gone the right way.
thas what i do
Old Mar 16, 2009 | 11:09 AM
WhiteBird00's Avatar
Ungrounded Moderator
You can't really use an ohmmeter to determine impedance because impedance and resistance aren't the same thing. For example, a 4-ohm speaker will often read 3.x ohms resistance across the terminals using an ohmmeter.
Old Mar 16, 2009 | 12:17 PM
Havoc54's Avatar
So I need to get the dual 2 ohm subwoofers and hook them up like this
And it will send 600 watts to each. correct?
Would this be the best way to wire it?
Old Mar 16, 2009 | 01:33 PM
pentavolvo's Avatar
yes
yes
yes
Old Mar 16, 2009 | 01:51 PM
Havoc54's Avatar
Originally Posted by pentavolvo
yes
yes
yes
I'm assuming that means yes to all 3 questions..
Thanks for the help guys
Old Mar 16, 2009 | 02:18 PM
Engine_HP's Avatar
ur correct,
last time i measured the resistance of a 4ohm speaker it read somthing like 4.2X, u will not get 100% acurate reading but ull be somwhere close.
