Rear Defroster Not working tab fell of window
I'm looking for some help. My rear defroster in my camaro is not working because the drivers side tab has fallen off the window in the rear. Can anyone recomended a product or a way to fix this.??? I believe a conductive epoxy or adhesive is needed? Thanks for the help Bryan
Save the manuals!
Solder. You will probably need a high wattage solder gun. (Not a soldering pencil, like you'd use with a circuit board.)
Post #4 in this thread has the procedure from the GM factory service manual: Rear defroster detached from Window, how to reattach?
An auto glass shop should also be able to do this for you cheap.
