BCM help...
Old May 20, 2009 | 10:54 PM
C Murda's Avatar
Default BCM help...
ok so for some reason i believe there is something shorting out with the BCM wiring and my gauge cluster wiring.... my car has no power options so there are only 2 plugs going to the BCM. can someone PLEASE give me a pinout of the large 32 pin blue connector and the 8 pin connector.
also along with that, if a certain wire is "switched 12v" then it should not have power until the key is switched to accessory mode correct? so to test for this i can just use a test light and ground out the switched wire and it should not light up until i switch the key right?
Old May 20, 2009 | 11:05 PM
shoemike's Avatar
BCM Connectors.zip
Old May 21, 2009 | 09:37 AM
C Murda's Avatar
^^^^ not working says it "corrupted"
Old May 21, 2009 | 09:45 AM
shoemike's Avatar
i just downloaded it and it worked for me.
It is a word document.
I can't edit it into a JPEG etc. because my PC with office has a broken system board.
Old May 21, 2009 | 09:57 AM
C Murda's Avatar
what the hell just tried again...i downloaded it went to open and still says corrupted...right clicked and went to extract and says no files???
Old May 21, 2009 | 11:37 AM
shoemike's Avatar
Try this: BCM Connectors.txt
Old May 21, 2009 | 11:45 AM
WhiteBird00's Avatar
Ungrounded Moderator
Green Connector
A TAN Driver Door Unlock
B GRY Lock All Output
C RED/BLK Lock All Input
D ORN/BLK Unlock All Input
E GRY/BLK Passenger Door Unlock
F -- Not Used
Black Connector
A BLK Ground
B ORN Battery Positive Voltage
C DK BLU Retained Accessory Power (RAP)
D BRN Accessory Positive Voltage
E DK BLU/WHT Courtesy Lamps Feed
F RED Battery Positive Voltage
Blue Connector
C1 BLK Ground
C2 PPL/WHT Ignition Key Resistor Return
C3 -- Not Used
C4 PPL/WHT Fasten Seat Belt Indicator Control
C5 DK GRN Starter Enable (V6 VIN K)
C6 DK GRN/WHT Vehicle Speed Input (Gulf States)
C7 GRY Interior Lamps Command Input
C8 BLK/WHT Park Lamps Relay Control (Domestic)
C8 YEL Rear Fog Lamp Relay Control (Europe)
C9 BLK Horn Relay Control
C10 -- Not Used
C11 YEL/BLK Starter Relay Control (Domestic)
C12 GRY Security Indicator Lamp Control
C13 BLK/WHT Seat Belt Switch Signal
C14 LT GRN Ignition Key Signal
C15 -- Not Used
C16 DK GRN Security LED Control
D1 WHT Courtesy Lamps Return
D2 LT BLU Shock Sensor Tamper Input
D3 BLK/WHT Rear Compartment Lid Release Signal
D4 BRN Rear Compartment Lid Release Relay Control
D5 PNK Ignition Positive Voltage
D6 YEL Program Input
D7 WHT/BLK Ignition Key Resistor Feed
D8 DK BLU Fuel Enable
D9 LT BLU Rear Fog Lamp Request (Europe)
D10 -- Not Used
D11 GRY/BLK Driver Door Open Input
D12 BLK/WHT Passenger Door Input
D13 ORN/BLK Rear Compartment Lid Ajar Input
D14 LT GRN Shock Sensor Shock Input (Domestic)
D14 BLK Ground (Europe)
D15 BRN Park Lamps Feed
D16 -- Not Used
Old May 21, 2009 | 12:02 PM
shoemike's Avatar
Old May 21, 2009 | 01:46 PM
C Murda's Avatar
Oh awesome thanks!!
