Paging whitebird for some blinker help
https://ls1tech.com/forums/stereo-el...er-wiring.html
but design has changed now i have a strip of led's for the drl's and i want it to double duty as the blinker, but i dont know how that whole double filliment thing is going to work out as i know now that the drl module controls the dim and high filiments according to the headlights being on
thanks for the help
All you have to do is cut the blue wire on each side and use it to power your LED lights - the logic of DRL versus turn signal is already taken care of for you by the DRL module. Leaving the original brown and black wires ensures that the parking lights will still work with the headlights as they're supposed to.
seems so easy to me,
but thanks alot when im finished ill be starting a new thread in the appearance section that has finished pics of the new bumper and the new drls
its actually on right now but i wired the leds up to my fogs (i dont have any right now) so i could decide on mounting
but thanks again for all your help
yeah that got it (lack of knowledge usually the problem huh)
Different set of led straps with a switch back functiom I've got the drl module mode covered looking st other conversarions i can just bypass the drl so the blinker function will work. Ive gott tk give the primary drl a switched ignition voltage, what im curious on is where is the best place to access those wires? Is there a place in the dash to feed that into the inside fuse panel?
I've gone to great lengths to clean up wiring innthe engine bay and while i can do more and tap into the engine bay, i have a plan to delete a lot of useless wiring since I'm running a stand alone ecm leaving a lot of the 2 fuse panels kind if vacant, but doing it from inside the cabin might be cleaner? I soldered in a 3 line duetch connector for the DRL's. This curre tky functions as we originally discussed where they behave as DRLs until switching the blinker. Once the see a signal onbthe blinker wire they will cycle a sweeping yellow led, just need the third wire enabled currently they just switch off.
So as I understand it if i bypass the drl module and give the Drl a separate switched ignition source via the brown wire, and repin the blue wire to the blinker signal all is good. Just wondering if the brown wires go into the cabin. Part kf the DRL module connections?
I'm not sure I get the rest of your question... you may have been using your phone so there's a lot of typos. What is a "duetch" connector?
The brown wire is part of the parking/running light circuit. It powers the tail lights, side markers, and the dim filament of the front lamps as well as the dash illumination. Yes, it is available inside the cabin at the headlight switch - but NO, you should not use it. There is no easy way to isolate the wires going to the front parking/turn signal/DRL lamps from the rest of the circuit, so you'd end up providing ignition power to all of your exterior lamps plus the dash.
I was trying to avoid doing it all in the engine bay cause of the difficulty accessing my fuse panel. It's below the engine bay in the area beneath the head light. Sounds like I just need to send a wire from each brown wire and merge it near the fuse bank and plug it in there like in your link
got it sorted out finally, blinkers work and DRL's behave. Got an atm style fuze tap and used it in a empty slot in the engine bay buse panel. Tucked the wiring in the bumper and once i put the splash panels on youll never see it.
Thanks for the help!
