Raptor install question
Old Aug 10, 2009 | 09:38 PM
sum12nv's Avatar
Default Raptor install question
Alright guys I need some help. I ordered a raptor because I thought my harlan was bad but now am wondering if its something else thats causing the problem because im having the same issues as I did with the harlan.
I have the red wire ran to a switched power source, black wire ran to a ground under the dash and the green wire ran up to the lower pcm harness or one farthest away from firewall connected to the white wire coming out of pin #10. The shift light blinks back all the correct sequences for my selection just no light at the desired rpm? From everything ive read I would think I have it hooked up properly. I have it set on 4 cyl mode which is 1-down 2-up 3-down on the dip switches and have the rpm selection at 2500 rpm just to test and im not getting anything when im at that rpm.
I thought maybe at first that the original scotchlock wasnt doing the job so I ran the new green wire from the raptor and soldered it into the tach line and still nothing. Please help
Old Aug 10, 2009 | 09:45 PM
67goatman455's Avatar
um....you have it set on 4-cyl mode?
Old Aug 10, 2009 | 09:54 PM
marksls1ta's Avatar
you have it tied to the red or blue set on the computer?
Mark
Old Aug 10, 2009 | 10:20 PM
sum12nv's Avatar
Mark
I dont know which is red or which is blue. This is where its wire in at.
Thanks in advance!
Old Aug 10, 2009 | 10:24 PM
marksls1ta's Avatar
http://www.raptorperformance.com/Ins...c/firebird.htm
Old Aug 10, 2009 | 10:28 PM
sum12nv's Avatar
"1999-2002 LS1, 5.7L equipped Firebirds: tach wire is pin #10 on red PCM connector, white wire." I have a 2000 t/a with a LS1 Isnt that where i have it wired up to?
Old Aug 10, 2009 | 10:32 PM
marksls1ta's Avatar
sure is. check to make sure the push pins are all the way up/down.
what RPM you have it set?
Old Aug 10, 2009 | 10:35 PM
CaMaRo67RS355's Avatar
im having trouble with mine it lights up when you cut the key on but does not light up when the shift point comes up, is there a quick fix?
Old Aug 10, 2009 | 10:38 PM
sum12nv's Avatar
Yeah they seem to be all the way up or down and im getting the correct 4 flashes back when the ignition is on for 4 cyl mode. Ive been just testing it out in the garage and since i dont want to wake up the whole neighborhood ive tried it at 2300 and 3100 rpm just to test and it didnt light up either time at those chosen rpm settings.
Old Aug 10, 2009 | 10:51 PM
marksls1ta's Avatar
Hmm let me call Raptor in the AM and I will see what is up.
Thanks,
Mark
Old Aug 11, 2009 | 06:38 AM
sum12nv's Avatar
Thanks,
Mark
That would be great, Thanks Mark!
Old Aug 11, 2009 | 06:41 AM
Engine_HP's Avatar
Thanks in advance!
look at the seel colour from the inside
Old Aug 11, 2009 | 11:59 AM
sum12nv's Avatar
Thanks for the info!
Old Aug 11, 2009 | 04:01 PM
Engine_HP's Avatar
i took alook today.
actually its not the seal its the plastic that the pins fit in.
sorry about that.
Old Aug 11, 2009 | 04:23 PM
sum12nv's Avatar
i took alook today.
sorry about that.
Yeah i knew what you were meaning.
Old Aug 11, 2009 | 04:27 PM
sum12nv's Avatar
So I guess the other question I should be asking is it possible for my factory tach signal to be coming from somewhere else other than the #10 pin white wire coming off the red PCM? Is there another tach wire that I could splice into other than the one coming out of the pcm? I got the suggestion to splice into the wiring on the injectors and change it to 1 cylinder mode on the shift light but dont really like the idea of that. Any more help would be much appreciated. Thanks!
Old Aug 11, 2009 | 04:29 PM
marksls1ta's Avatar
I called Raptor today and the idea of splicing in the injectors is what they said.
Mark.
Old Aug 11, 2009 | 05:20 PM
sum12nv's Avatar
Just for my own personal test I just cut the #10 pin white wire coming from the red PCM in half to see if the tach wouldnt work anymore and it still does???
Would it be possible that my 2000 has a pcm out of another year? I noticed on harlans website that 1998 is different than 99-00 but didnt say anything about 2001-2002. To me if i cut the tach signal wire I wouldnt be getting a reading on the factory tach, am I right?
Old Aug 12, 2009 | 05:14 PM
sum12nv's Avatar
bump... anyone have any other ideas?
Thanks!
Old Sep 4, 2009 | 08:00 PM
RiceEaterZ's Avatar
any update on this? I have an 02 Z and just got a raptor today, wondering before I go and try to install, I have blaster coils so there won't be any wiring to that for me.
