Elemental Designs Blowout sale....!
Lol, possibly literally. I just replaced mine a month ago so I'm pretty pissed i had to pay full price, but I figured I'd pass this along.
from 85 to 40bucks each!!!
Time to do that sail panel subwoofer replacement, for dirt cheap.
(pontiacs need the 4ohm subs and chevy's the 2ohm)
![](http://www.edesignaudio.com/logos/e6_3_main.jpg)
http://www.edesignaudio.com/product_...products_id=33
By the way, I did the swap and It's amazing. I only used a 3/8" plywood spacer and didn't cut any holes...
install link.
install link.
yeah d-4. and the space is really simple, some people even make them out of styrene
Maybe i'm wrong as I haven't really done the research for the cars i don't have...but i know how the pontiac's go for sure.
the camaro only has 2 wires....
Ungrounded Moderator
Camaros have 2-ohm single voice coil subs so they have just one pair of wires that should produce a 2-ohm load for the amp. If you use 2-ohm DVC subs, you'll have to connect only one of the two voice coils - losing about half your power. You can't wire the two voice coils together in parallel because you end up with a 1-ohm load that the amp can't handle. And if you wire the two voice coils together in series you end up with a 4-ohm load which still cuts your power in half.
That's why you need the same 4-ohm DVC sub in a Camaro as in a Firebird. You wire the two voice coils together in parallel to create a 2-ohm load and then connect the resulting two wires to the factory pair of wires. In essence you are converting a 4-ohm DVC sub into a 2-ohm SVC sub.
Yes, your Firebird has 4-ohm dual voice coil subs from the factory so replacing with eD 4-ohm DVC subs is a simple matter of hooking up the four wires.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Would these be a good start for what I'm looking for?
https://ls1tech.com/forums/stereo-el...ions-my-t.html
thanks.
thanks.
