Sub install problem
Old Oct 18, 2009 | 02:11 PM
sixtyfive's Avatar
Default Sub install problem
Problem -
Sub does not sound right
Sub thumps when amp turns off
When volume is all the way down on the head unit i still hear a steady low vibration from the sub
Sub freaks out when volume is up
Here is what I am working with -
JVC Arsenal KD-AR7000
Kicker KX600.4
10" JL in a stealth box
Stock monsoon amp is running all the stock speakers, woofers, and tweeters
Setup -
I had this same setup in my camaro and I am currently transplanting it into my trans am.
In the camaro I had 4 speakers wired to AMP1 of the Kicker, and the sub run off AMP2 of the kicker.
In the trans am I am only using the amp to run the sub. Thus I am only using AMP2. I have the sub bridged using L+ and R-.
I have checked to make sure I am properly grounded and that the sub is hooked up with + to + and - to -
What should I try next to troubleshoot this problem?
Thanks!
Old Oct 18, 2009 | 10:13 PM
bmnicolosi's Avatar
Possible bad ground, I've seen that a few times with a bad ground.
Old Oct 18, 2009 | 10:19 PM
00RedMaro's Avatar
It happened to me in my camaro and it was due to a bad ground. These are some of the hardest cars to do a system in.
Old Oct 18, 2009 | 10:44 PM
N20zuki's Avatar
That and running your power wire along side of your RCA cables will casue this too
Old Oct 19, 2009 | 10:06 AM
sixtyfive's Avatar
Thanks guys, Ill try grounding to a new spot tonight.
I have power run down passenger side and RCA's down drivers side.
Old Oct 19, 2009 | 10:15 AM
b's90cam's Avatar
Is your amp turn on hooked up to your remote turn on off the HU or off the switched ignition? This was my problem for a while. Needs to be HU amp remote turn on.
Old Oct 19, 2009 | 01:21 PM
94'BLKBRD's Avatar
I tucked in the wiring under the center console(drivers side), then under the carpet. You can run it along the the side panels too.
Old Oct 19, 2009 | 10:15 PM
sixtyfive's Avatar
I have the amp turn on wire run to the remote turn on\off on the HU. Is that how it worked for you?
Old Oct 19, 2009 | 10:46 PM
sixtyfive's Avatar
Moved my ground from the bracket below the antenna motor, to the sheet metal of the wheel well.
Made sure I sanded it good.
Here is how my amp is setup. If i turn the gain and bass boost down the idle sound (when HU volume is at 0) is less noticable
Old Oct 20, 2009 | 08:55 AM
sixtyfive's Avatar
Sub works fine when volume on HU is below 19.
It was freaking out when volume was at about 26 out of 50ish.
Old Oct 20, 2009 | 01:53 PM
bmnicolosi's Avatar
try changing to amp1 on the amp to see if it continues
Old Oct 21, 2009 | 12:01 AM
sixtyfive's Avatar
That did the trick! I am guessing maybe you have to use Amp1 before using Amp2?
I love easy fixes
