Defroster switch...
Old Nov 8, 2009 | 09:42 AM
  #41
Adam2001WS6's Avatar
Well, put the fuse in and it seems to be working fine. Timed it and it stayed on for exactly 10 minutes. I still don't understand why the circuit breaker doesn't work.... Is it essentially the same technology?
Old Nov 8, 2009 | 10:09 AM
  #42
WhiteBird00's Avatar
Ungrounded Moderator
You're right - there is no reason a new circuit breaker shouldn't work just as well as a fuse. As long as they both pass the required current without blowing, there should be no difference in operation. It is possible that the new circuit breaker you bought is defective.
Old Nov 9, 2009 | 09:01 AM
  #43
wssix99's Avatar
Save the manuals!
I'm wondering if the tint could conduct additional current through the defroster. The fuses look like they actually blow at a higher amperage (just over 40A for a 30A fuse) http://www.cooperbussmann.com/pdf/56...8673caf2e6.pdf than the breakers, which drop their trip point as the temperature increases. http://www.cooperbussmann.com/pdf/d6...f1cda0ad62.pdf
Either way, the fuses look to be more stout as they blow at higher power at higher temperatures.
Old Nov 9, 2009 | 05:37 PM
  #44
Which leads me to believe that circuit breakers are safer in the sense that they keep things from frying while the fuse "lasts" longer, although dangerously...
Old Nov 9, 2009 | 06:14 PM
  #45
SparkyJJO's Avatar
Glad I just saw this post, my defroster in the back has been acting screwy recently, randomly kicking off after only a min or two, and not turning back on. Now I know what to do about it
Old Nov 14, 2009 | 02:40 PM
  #46
1Bad97WS-6's Avatar
Mine defroster work fine. But at Idle turn it on the amp gauge drops to a little less then 13 some times to 13. Turn it back off it goes back to normal I geuss. Some times going down the road my light dim and go back to normal.
Old Nov 17, 2009 | 09:02 AM
  #47
j-man's Avatar
This is great info! I have been ignoring the same issue for a couple of years now! Thanks LS1tech!
Old Nov 17, 2009 | 12:49 PM
  #48
99NBMZ28's Avatar
me too lol, i just thought thats how it worked.
Old Nov 30, 2009 | 02:51 PM
  #49
maroon3.8cam's Avatar
Default No light, but clicking?
Hey guys i have a question about this, i changed my 30 amp breaker for a fuse and when i click my defrost i hear it click but no light turns on and the rear window does not get hot? How could i fix this or what could it be? ive been reading and my only guess would be to actually change that little module in the HVAC or swap it off of a used or junked camaro? Its really bugging me!
All help is appreciated,
Thanks in advance, Pawel
Old Nov 30, 2009 | 07:01 PM
  #50
Anybody!?
Old Jan 15, 2010 | 06:27 PM
  #51
Joshiedoom's Avatar
I did this same thing and had an issue with 30amp fuse to keep blowing, did it twice tonight when playing with the seat controls and the defogger.
Old Jan 17, 2010 | 04:10 PM
  #52
The 30 amp fuse should be enough for the defroster OR the seats but often not for both at the same time. If the fuse blows while using just one or the other then you have an electrical problem that needs to be tracked down (such as a short in the defroster grid).
Old Jan 20, 2010 | 02:29 PM
  #53
Joshiedoom's Avatar
Changed back to the breaker... both work great, even together..wierd
Old Jan 20, 2010 | 03:06 PM
  #54
DAVE00's Avatar
Just move to Texas and you won't have to use your defroster - LOL. I can't even tell you the last time I turned mine on, maybe 8-9 years ago.
Old Feb 1, 2010 | 10:38 PM
  #55
AR15 guy's Avatar
I have been annoyed by this for almost a year now and finally decided to check into it. I feel like an *** for waiting so long now lol.
Old Mar 13, 2010 | 01:20 PM
  #56
GotGrunt's Avatar
My defroster switch doesn't light up when I press the button but the power seat works as it should. Is there anything specific I should be looking at? If the switch is the culprit, I have to purchase the entire HVAC unit?
Old Mar 13, 2010 | 04:19 PM
  #57
wssix99's Avatar
Save the manuals!
I'd start with the circuit breaker. The defroster pulls more current than the seat.
Old Mar 13, 2010 | 04:57 PM
  #58
GotGrunt's Avatar
Where exactly is this circuit breaker located? I just picked up my Camaro and I'm new to LS1 cars. I don't have the owners manual with the fuse breakdown.
Old Mar 14, 2010 | 07:22 AM
  #59
The circuit breaker is in the fuse panel on the left end of the dash with the other fuses. It looks like a small silver box plugged into a fuse socket.
Old Mar 14, 2010 | 10:07 AM
  #60
wssix99's Avatar
Save the manuals!
You can get a new owners manual here: http://www.helminc.com Its a good $5-10 to spend.
