Thinking of eDead...Worth it?
Old Nov 8, 2009 | 06:32 PM
homerunhtr21's Avatar
Default Thinking of eDead...Worth it?
I have 1 chamber flows dumped under the rear axle (head/cam) and I am wanting to get it "quieter" inside the car. The bass from the Ed subs sounds great when the car is off but once the car is started it basically goes away. Will the eDead help with this and get rid of the ashtray rattle and interior vibrations or is it not worth it?
Old Nov 8, 2009 | 11:54 PM
pentavolvo's Avatar
its will help but only can do soo much. PM 69z-28 he did his TA and camaro all out in edead and was very happy with it, reduced alot of road noise and rattles
Old Nov 11, 2009 | 07:34 PM
trx250r's Avatar
i have heard good things about second skin. http://www.secondskinaudio.com/
Old Nov 12, 2009 | 02:50 PM
94'BLKBRD's Avatar
Go with Second Skin.
Old Nov 14, 2009 | 08:58 PM
hadkin's Avatar
I'm using Dynamat and I'm happy. car sounds much louder when i roll down the windows
Old Nov 15, 2009 | 05:38 PM
spanky_55amg's Avatar
Hello
Thanks for your interest in Second Skin!
Damplifier Lite is a great product but for a TA, you will need more.
I would go the route of our SPL tiles.
get a box of 80 tiles, which is 28 lbs, and patch them in the car all around the sheet metal. This will do an awesome job at absorbing the structure borne noise and will kill the drum effect inside the car.
The next layer you can di is our Luxury Liner Pro, but this is 1.15 lbs psf, and your TA will need about 60-70 sq feet. So that one will get heavy.
A light weight option would be our Heat Wave Pro. This is a very popular material for gusy that are trying to reduce heat and noise. Putting it on top of the SPL Tiles is a great way to accomplish your goals without adding much weight at all.
Feel free to call me with any questions:
623.533.8193
I will be happy to set aside some time to discuss your project further.
ANT
service@secondskinaudio.com
c.623.533-8193
f. 602.272-3447
this is what i got from the guys at second skin
Old Nov 16, 2009 | 02:04 PM
Dal1as's Avatar
Do not use edead, especially since you're in a warmer climate. It melts and makes a mess. Use something else like second skin or dynomat.
Old Nov 16, 2009 | 02:18 PM
Ericbigmac83's Avatar
Ive heard it can have issues in warmer climates, I haven't had any problems yet personally. for the price tho its great
Old Nov 17, 2009 | 08:41 AM
j-man's Avatar
Just editing out my joke I will give Edead the benefit of doubt. Maybe my experience was with early edition product. I will still pimp the Second Skin Damplifier Pro though! Very effective product!
Go with Second Skin products or Dynamat Xtreme. I have both on my doors and will be using only Second Skin on the rest of the car.
Old Nov 17, 2009 | 12:13 PM
pentavolvo's Avatar
sorry i disagree had a car with edead on roof sold car after 3 years no issues at all, some of the very early edead had issues but after that it didnt
i know a number of guys with fully edead'd cars with no issues at all
Old Nov 17, 2009 | 05:23 PM
trx250r's Avatar
my buddy used about a roll and a half of edead in his car an it stays put in the summer....
if youre interested in second skin i know an offer code for 15% off 40sqft of damplifier.
Last edited by WhiteBird00; Nov 20, 2009 at 07:35 AM. Reason: consecutive posts merged
Old Nov 17, 2009 | 06:33 PM
j-man's Avatar
Originally Posted by spanky_55amg
Hello
623.533.8193
ANT
c.623.533-8193
f. 602.272-3447
ANT! I didn't know you were an Fbody guy
Thanks again for your help and service
Jman
Old Nov 17, 2009 | 09:51 PM
scj's Avatar
scj
best mod to my car; before i sold it obviously. but i loved it!
Old Nov 18, 2009 | 12:48 PM
Dal1as's Avatar
Mine has stayed put but has turned in to a gooey mess in places, especially where the spare tire goes. This is in Maryland and after my car had to sit in the driveway a couple summers ago. (Garage was full of kids stuff) It's tar based and will melt.
Old Nov 18, 2009 | 10:09 PM
Casper9T9's Avatar
I used Second Skin Damplifier in my truck. If that's too pricey for you, go with RAAMat. That's the only "economy" sound deadener I would consider buying. All the other stuff is cheaper because it's thinner and uses lower quatlity materials. You get what you pay for.
Old Nov 20, 2009 | 04:59 AM
witHonor's Avatar
I did a ridiculous, over the top sound deadening install. One of the reasons for it was exhaust noise. In sixth gear at around 2k RPM or lower there is a very deep, constant noise which is annoying and makes sixth gear sort of useless because I have to go over 80MPH to make the noise bearable. Even after the sound deadening, the noise deep tones are still too much but everything else is very quiet. Also it made my sound system sound a lot better.
If you care to look at what I did, you can see it here and here.
I used eDead after a lot of research and have had no problems with it. Older stuff was an asphalt product and that is the reason for most complaints. The current product is butyl like Second Skin and RAAMat.
Old Nov 20, 2009 | 08:07 AM
dragonrage's Avatar
Luxury Liner will do more for road noise than mat. I had RAAMMat and TWO layers of LL in my Camaro. That thing had no road noise coming through the floor.
Old Nov 21, 2009 | 02:11 AM
witHonor's Avatar
That's like the eDead V4 Teklite I used, only the V4 is self adhesive which I think was easier to use. I couldn't imagine putting more the one layer of that on because I had a hard time getting some panels to go back on with just one layer.
Old Nov 21, 2009 | 08:26 AM
porksoda's Avatar
Edead has a 25% off coupon right now too.
Old Nov 21, 2009 | 10:13 AM
dragonrage's Avatar
I only did the LL under the floor. The doors only had RAAMMat and some Second Skin sludge. They still let noise in, though not as much as stock. The car went back together easily, just that I needed to press down really hard to get the bolts for the center console to hook (I made the holes through the LL first but it was still a pain).
